  4. I can't update maps
I can't update maps
6 Posts 6 Posters 561 Views 2 Watching
  • pandreuundefined Offline
    pandreu
    Hello. Great Job!
    A problem: The map update doesn't work for me
    • Jörgenundefined Offline
      They are working on this.
      iPhone 12 pro (iOS 17.0.2)
      Oukitel RT3 (Andr. 12)
      Samsung Galaxy XCover 4 (Andr. 9 Pie)
      For more information, click here
      • ajaxundefined Offline
        ajax
        I'm having the same problem. Getting the message "A map update is mandatory before you can continue. It is recommended to use Wi-Fi when downloading maps". Current v.83 New v.88. I'm clicking on the yellow 'Download update' box but nothing is happening? This is preventing me from using offline maps.
        • Con Hennekensundefined Online
          Having "mandatory" map updates is a sign of corrupted local map data. Most likely caused by interrupting map downloads by force closing. Usually this will be cleared up. But sometimes indeed it may be necessary to delete app data in the Android Settings. How this works for IOS: no idea 😉
          Mario Ivancicundefined Rob Verhoeffundefined 2 Replies Last reply
            Mario Ivancicundefined Offline
            Mario Ivancic
            Map update is ..... (i do not want to be rude).... always some problems.... now im trying to update map that is only 206mb for almost two days. And i need to go to trip... so i will probably go with some other app.
            This is really basic stuff for navigation app... and it is not working for me.
              Rob Verhoeffundefined Offline
              @Con-Hennekens said in I can't update maps:
              Not possible in iOS. Usually you can go to Settings > General > iPhone Storage > MyRoute-app > Clear data or cache or what so ever.
              Mario Ivancic
              ajaxundefined
              ajax
              pandreuundefined
              pandreu
              • Waypoint / Viapoint Icons
              • Tracklog omzetten naar route geeft veel verschillen
                Bouke Entundefined
              • Waypoints (Again!)
                Lex.Kloet.RXundefined
                Lex.Kloet.RX
              • MRA is only speaking with French accent??
              • Implement 2FA for login
                Rainer Treichelundefined
                Rainer Treichel
              • different results with different phones!
                D Griffinundefined
                D Griffin
              • Clear Directions
              • Scenic routing & RouteXpert library improvements
                8.4k
