  2. Routes & Tracks
  3. Copying a route
Copying a route
5 Posts 3 Posters 313 Views
  • Colin Hodgkinsonundefined Offline
    Colin Hodgkinson
    I have made a route with over 40 waypoints but would like to reproduce it as a separate route rather than re create another 40 point route. The reason is that the weather may not favour the whole route so i will cut it in half. I know that split route is an option but the route we are completing is a circular route.
    • Colin Hodgkinsonundefined Colin Hodgkinson
      @Colin-Hodgkinson, and what exactly is the problem? A circular route does not prevent it from splitting, does it?
      Colin Hodgkinsonundefined 1 Reply Last reply
        Colin Hodgkinson
        @Con-Hennekens I hear what you are saying but splitting this route will actually make two separate routes.
        Nick Carthewundefined 2 Replies Last reply
          @Colin-Hodgkinson Make a copy of the original route and split the copy. Let’s say that you split your 40 route point route at number 20.
          The first of the 2 split routes 1 - 20 would be your alternative route, I would adjust the route name and plot the route from RP20 back to your start point.
            @Colin-Hodgkinson Actually, you don’t need to make a copy of the original route as the two split routes are new routes.
            Colin Hodgkinson
            • Was sind Saisonale Schliessungen? - What are seasonal closures?
              Rainer Treichelundefined
              Rainer Treichel
            • A -> B route Automatic recalculation always active
              Rainer Treichel
            • Improve Favorite POI management (visibility, categories, icons)
              Roberto Arundefined
              Roberto Ar
            • App crashes
              Jeroen 1sundefined
              Jeroen 1s
            • Tracklog lost
            • Gemiddelde snelheid van geplande route aanpassen
            • In App route planner werkt niet
              Edwin_Mundefined
              Edwin_M
            • Neu aus Ingolstadt
              Lex.Kloet.RXundefined
              Lex.Kloet.RX
