  2. Routes & Tracks
  3. Seasonal closures
Seasonal closures
10 Posts 3 Posters 2.4k Views
  • Colin Hodgkinson Offline
    Colin Hodgkinson
    I am trying to place waypoints from Aosta to the petit St Bernard pass via La thuile on the ss26. I have disabled seasonal closures but it still takes me a different route, no matter how many waypoints i put in to dissuade it otherwise! Any thoughts?
    • Colin Hodgkinson Colin Hodgkinson
      Jack van Tilburg Offline
      Jack van Tilburg
      @Colin-Hodgkinson
      I try to create the situation but have no problems with the route.
      Maybe it would be better if you put a link to your route here.
      Don't forget to set the privacy setting to 'public'.
      Colin Hodgkinson 2 Replies Last reply
        @Colin-Hodgkinson
        Colin Hodgkinson
        @Jack-van-Tilburghttps://www.myrouteapp.com/en/social/route/7055137?mode=share
          @Colin-Hodgkinson
          Colin Hodgkinson
          @Jack-van-Tilburg Its at point 13, that we want to continue on the ss26 but it detours south.
            Jack van Tilburg
            @Colin-Hodgkinson
            Is this what you want?
            https://www.myrouteapp.com/nl/social/route/7430910?mode=share
            Colin Hodgkinson 1 Reply Last reply
              @Colin-Hodgkinson
              Colin Hodgkinson
              @Jack-van-Tilburg Jack, you are a magician. I have no idea what I was doing wrong but I could not get it to follow the route on the ss26 as you have done, even with seasonal changed. Thank you.
                Jack van Tilburg
                @Colin-Hodgkinson
                I only placed some extra points at strategic places 🙂
                  @Colin-Hodgkinson
                  Colin Hodgkinson
                  @Jack-van-Tilburg Every day is a schoolday. Thank you
                  Colin & Jackie retired and lost!
                    Jack van Tilburg
                    @Colin-Hodgkinson
                    What helps with route planning is adjusting the transparency of the route line.
                    I set it to 60%. This way you can see from the route line if a given route is traversed twice as it is darker there. To avoid this, you should play with the position of a waypoint in this case.
                    • Spili Offline
                      Spili Offline
                      Spili
                      Change map for TomTom... There works ok with Seasonal Closures.
                      Colin Hodgkinson
                      Colin Hodgkinson
                      Spili
                      Spili
                      Jack van Tilburg
                      Jack van Tilburg
                        Sytze van der Laan
                        Sytze van der Laan
