  2. Routes & Tracks
  3. Seasonal closures
Seasonal closures
10 Posts 3 Posters 1.5k Views
  • Colin Hodgkinsonundefined Offline
    Colin Hodgkinson
    I am trying to place waypoints from Aosta to the petit St Bernard pass via La thuile on the ss26. I have disabled seasonal closures but it still takes me a different route, no matter how many waypoints i put in to dissuade it otherwise! Any thoughts?
    • Colin Hodgkinsonundefined Colin Hodgkinson
      Jack van Tilburg
      @Colin-Hodgkinson
      I try to create the situation but have no problems with the route.
      Maybe it would be better if you put a link to your route here.
      Don't forget to set the privacy setting to 'public'.
      Colin Hodgkinsonundefined 2 Replies Last reply
        @Colin-Hodgkinson
        Colin Hodgkinson
        @Jack-van-Tilburghttps://www.myrouteapp.com/en/social/route/7055137?mode=share
          @Colin-Hodgkinson
          Colin Hodgkinson
          @Jack-van-Tilburg Its at point 13, that we want to continue on the ss26 but it detours south.
            Jack van Tilburg
            @Colin-Hodgkinson
            Is this what you want?
            https://www.myrouteapp.com/nl/social/route/7430910?mode=share
            Colin Hodgkinsonundefined 1 Reply Last reply
              @Colin-Hodgkinson
              Colin Hodgkinson
              @Jack-van-Tilburg Jack, you are a magician. I have no idea what I was doing wrong but I could not get it to follow the route on the ss26 as you have done, even with seasonal changed. Thank you.
                Jack van Tilburg
                @Colin-Hodgkinson
                I only placed some extra points at strategic places 🙂
                  @Colin-Hodgkinson
                  Colin Hodgkinson
                  @Jack-van-Tilburg Every day is a schoolday. Thank you
                  Colin & Jackie retired and lost!
                    Jack van Tilburg
                    @Colin-Hodgkinson
                    What helps with route planning is adjusting the transparency of the route line.
                    I set it to 60%. This way you can see from the route line if a given route is traversed twice as it is darker there. To avoid this, you should play with the position of a waypoint in this case.
                    • Spiliundefined Offline
                      Spili
                      Change map for TomTom... There works ok with Seasonal Closures.
                      Spiliundefined
                      Spili
                      Jack van Tilburg
                      Colin Hodgkinson
                      • Unable to calculate route
                        Aiello antoninoundefined
                      • TTS Engine Voices - Android DMD T865X
                      • Absurd detours on the highway maps HERE
                      • Continuous freezing on Android Auto
                        b0hd1undefined
