  4. Route changes inadvertedly in test flight
3 Posts 3 Posters 55 Views
  • Nicola Hardmeier
    Nicola Hardmeier
    Nicola Hardmeier
    When I open a route with test flight it appears as i planned (pic.1)
    when I press navigate the route changes!!! (pic2).
    How to avoid this?
    Ian foster 0 Corjan Meijerink 2 Replies Last reply
    • Nicola Hardmeier Nicola Hardmeier
      How to avoid this?
      Ian foster 0
      Ian foster 0
      Ian foster 0
      @Nicola-Hardmeier did you plan the route using the “here” map in route planner ? I had this when I planned a route with a different map as the navigation uses here so will be slightly different.
        How to avoid this?
        @Nicola-Hardmeier indeed as @Ian-foster-0 said. Routes must be planned with HERE too for a good result. The App does however take current information into account so if roads are closed due to accidents etc it might be that the app does something else than the website.
        In most cases the planned HERE routes from the website are navigated identical in the app! 🙂
        Nicola Hardmeier
        Nicola Hardmeier
        Ian foster 0
        Ian foster 0
        • Adding default break times for viapoint icons
          Lluís Casals
          Lluís Casals
        • Feature request: Het aanmaken en kopiëren van routes in een gedeelde bibliotheek
          Giancarlo e
          Giancarlo e
