  4. Navigate around road closures
19 Posts 9 Posters 326 Views 2 Watching
    @Dae-0, The skip-waypoint button is your friend. Then drive a different road that is NOT closed until the navigation goes forward again. Life is not that difficult. This will be done automatically of the auto-skip function is implemented. Then you can show the eyecandy to all that aren't using MRA 😉
    Dae 0
    Dae 0
    Dae 0
    Whilst your suggestion may work once you get the skip waypoint option in CarPlay, this thread is about suggestions for improvements and in my mind the other system that says “road closed for x miles, please sort me a way around it automatically and skip any necessary waypoints” is an improvement on doing it manually and riding until the the navigation takes you in the right function which could be miles away.
    It’s only by people providing experience of other systems and their opinion on shortcomings of MRA that Next can be the true king that’s it’s shaping up to be.
    Having an option for the system to do it automatically would be a win-win. Those who want it can use it and keep their attention on riding safely, whilst those who prefer to do things manually could simply not use the option and carry on doing what they’ve always done.
    • Dae 0 Dae 0
      @Dae-0, Automagically skipping waypoints is already working great in the old version, and ensures that you are not guided back if you mis a shaping-point (for whatever reason, roadblockage is only one). It will be implemented in Next too.
      I was not aware that the Carply screen does not offer the skip button. I was in no way rediculising your experience nor your comment. On the contrary, I was only trying to be helpful. Sorry if it was considered otherwise.
      • Tim  Thompson
        Tim  Thompson
        Tim Thompson
        I don't believe that MRA Navigation handles detours directly. It seems that it deals with such scenarios via one or two methods.
        1. You can set it to skip waypoints automatically.
        2. You can skip one or more waypoints manually.
        This might provide enough capability for some - depending on how they use the app and what their expectations are. But, as far as I can tell, MRA Navigation will not deliberately route you around waypoints and get you back on/to you intended route.
        Some other apps handle this more deliberately. Scenic for example has various options to handle detours...
        Detour behaviour when deviating from your route.
        Go to the link provided for more details on how it works.
        I don't encounter these scenarios very often (hardly ever) so I don't have a lot of personal experience with putting them to the test. However, I can see how they might come in handy.
        Maybe this sort of thing is what the OP has in mind and hopes to find some of this functionality in MRA someday.
        • Dae 0
          Dae 0
          Dae 0
          wrote on last edited by Dae 0
          This is the sort of feature the OP and I were thinking of (assuming we’re thinking the same thing)
          This system isn’t the prettiest, but it works and mirrors the experience I’ve had on previous systems. It’s also available in CarPlay on that system and means a couple of taps of large icons gets you back on route without having to figure anything out for yourself, meaning you can concentrate on riding/driving.
          • Michael Rhys
            Michael Rhys
            Michael Rhys
            wrote on last edited by Michael Rhys
            If you put a destination in and the navigator knows of a road block it will navigate you around it. If I plan a route, the navigator still takes me to the blockage, why can’t it just say road closed, navigate around it (but put me back on my route when it can), or as others have said route round it automatically. At the end of the day, if I am navigating a route, that has a road block, I want the option of not actually seeing it. If this is a mountain pass with no cut offs, then I don’t want to be sent to it to have to back track maybe for 15 miles to find another road. Better to not go to the blockage in the first place. This is not common to MRA, my tom tom rider shows the route with a no entry sign, but again no way to navigate around it. This happened to me at the weekend on a route with 3 road closures, added 2hours to my 6 hr ride.
            Adding this sort of functionality is the sort of thing that will make MRA unstoppable.
              We’ll research improving this! 🙂
              Thanks for the input
              • MotoCon
                I think this discussion is becoming rather hypothetical. Roadblockage is most of the time not announced, so no planner ever will be able to do something with it. It seems to be nice to be able to automate a detour like in @Dae-0 's example, but the truth is that most of the time the length of the blockage, or the length of the needed detour is completely unknown. If you know all those details, you will not need navigation to begin with.
                The example of Scenic that @Tim-Thompson provided looks great, but to be honest most of those option are exactly how the old navigation worked, and I expect that they will work alike in Next before public release. With one exception that stands out: Self-Correct looks to be very promising, and ensures that after a detour you go in the direction of the destination instead of in the direction of a WP earlier on the route. That is good!
                Stanisław Michael Rhys 2 Replies Last reply
                  @Con-Hennekens I suppose we should talk rather about unexpected road blocs, for example because of an accident. I like the example shown by Dae 0, there is similar function in Tomtom - just two clicks to put an info that current road is blocked and I am getting 2-3 propositions of alternatives to get back to current path after a diversion. Additional info about length of blocked segment would be great. I suggest to take such function into consideration in next updates.
                  Staszek
                  • Tim  Thompson
                    Tim  Thompson
                    Tim Thompson
                    @Con-Hennekens said in Navigate around road closures:
                    Yeah... I've often wondered how certain scenarios like this would actually play out. I can see in some cases you might have to just make a SWAG about how far out you want to the detour to go. In other cases, you might end up just following the posted detour signs and just need the app to recognize when you are back on route (and automatically skip any missed shaping points). In some cases, the detour distance may be posted, so you'll know. One might be able to see the other side of wrecks or other obstacles in the road and be able to enter distance in easily enough in those cases.
                    Unfortunately, or fortunately, I don't get a lot of practice with these features to see how well they work and figure out how best to employ them. But I think having these features/options is a good thing as well as having flexibility/options in how to employ them.
                      Michael Rhys
                      Michael Rhys
                      Michael Rhys
                      @Con-Hennekens No one can expect you to react to closures you are unaware of. However comparing my tomtom rider 550. I have loads of routes stored and pick one I want to ride. Then whilst navigating, it shows a red no entry sign on the display showing me the road is closed in say 20 miles. But rather than giving me the option to route around it, it just counts down until I get there. So the satnav KNOWS of the blockage but takes no action. All I am asking for is in this situation a button that allows me to redirect around it without me being taken to the blockage, sometimes a better detour starts a few miles before the blockage than reaching it and following diversion signs (if there are any), whereby traffic may be heavy because everyone is doing the same.
                      • Dae 0 Dae 0 referenced this topic on
                      • nano
                        nano
                        nano
                        Hi everyone, I unfortunately opened another thread for the same topic. With 75k+ km using a Garmin device I like to add my +1 to the feature of having a button for a detour in case of e. g. roadwork or an accident or such. I am using it often on my Garmin device and it doesn't help always, but more often than not.
                        my thread with my thoughts on the topic
                        Dae 0
                        Dae 0
                        Michael Rhys
                        Michael Rhys
                        Steve Lynch
                        Steve Lynch
                        nano
                        nano
                        Tim  Thompson
                        Tim Thompson
                        • Route exporteren uit beta
                        • Startpunt wijzigen
                        • V6 - Track Navigation
                          Thomas Schäfer
                          Thomas Schäfer
                          1.7k
