  4. Carplay test
Carplay test
17 Posts 8 Posters 247 Views 1 Watching
  • Charlie Spicerundefined Charlie Spicer
    I've been using and testing the latest Beta Next App for the last two days in southern Ireland and each days distance is around 160miles/200kms.
    1st day issues were down to iPhone 13pro dropping internet connection which bombs out the navigation system and had to reset the route each time. However once I'd rebooted my phone the internet connection was fine.
    2nd day was almost trouble free apart from when there wasn't any internet ie no 3/4/5G the phone display goes almost blank with a spinning trying to connect message, however the CarPlay screen does continue to navigate correctly with no issues.
    Other points to note:
    If you disconnect the usb lead from the phone you instantly bomb out of the route and defaults back to the main map screen and of course have to load up the route again. Plus now you have to identify where you are and delete all the pervious waypoints. This is also a nuisance if you stop for a break half way through your journey and have to reload everything as above to continue.
    It would be good to have the option to mute all announcements both voice and beeps.
    The CarPlay screen doesn't display next waypoint info or fully mirror the phone screen info, so you have to have both visible to be fully informed.
    I have a more involved journey tomorrow from Killarney to Galway up the west coast which includes a 30 minute ferry crossing. Will post my findings soon after.
    So far the main issue is when the internet signal is poor and drops out the program takes too long to recalibrate/recalculate.
    Many thanks
    Charlie Spicer.
    @Charlie-Spicer many thanks for the great feedback!
    The main issue you mention about connecting / disconnecting and being bombed out of you navigation session has been fixed today! 🎉 We will most likely release a quick update end of this week for you all 🙂
    Regarding the announcements: you can turn these off from your phone settings (not yet in CarPlay).
    Offline maps can already be downloaded and offline routing will be added shortly! 😃
    Showing next waypoint info in CarPlay is something we’ll research.
    Appreciate the feedback and happy to hear you had no other big issues!
    • Jure Sirena 0undefined Offline
      Jure Sirena 0
      Today CP navigated with either app closed or screen locked. Also I see distance to next waypoint on CP screen, I was reading this was not working or?
      Still any stop of car, call...completely stops the navigation.
      • Jörgenundefined Offline
        Today the CarPlay screen was frozen when a WhatsApp message came, and I touched the screen for reading.
        The App was still running in the background, and the screenshot gave a different picture than the CarPlay screen.
        Interesting was that only the data at the CarPlay was updated in the background.
          This was with wired CarPlay System in Seat Arona.
          • Arno 0undefined Offline
            Arno 0
            Today my first A-B and B-A route Apple Carplay test with an iPhone in a VW. Seen the current limitations, I'm very satisfied with the results. The only comment I have is that I did not have the separate volume controls for the navigation and the radio from my steering wheel. Volume up or down worked the same for the navigation and the radio. On my way back from B-A, the volume control worked as expected and I adjust the navigation and radio volume separately. The iPhone got pretty warm but that is a known issue.
            • Arno 0undefined Arno 0
              @Arno-0 happy to hear that!
              • Charlie Spicerundefined Offline
                Charlie Spicer
                So todays Irish trip was 160 miles with 21 waypoints from Killarney to Galway on a chunk of the wild Atlantic way. All good until we had to switch off engine on a 20 minute ferry crossing, which again cuts the feed and bombs out CP and stalls the app on the iphone. Big time pain to fire everything back up and then delete all the previous weigh points to get going again.
                All good for 3km and internet drops for a moment and sends phone & CP into recalculating spin which doesn't recover but does stick to the route and passes through 2 weigh points but doesn't fully recalculate, rendering all the mileage data in a stall status. Had to pull over and restart and delete WP's to proceed with live info.
                Manageable agro in a car but would be a super pain on a bike if you're leading a few guys on a tour.
                When everything is trouble free it works perfectly, however a slight glitch can undo things too easily. I'm sure these are probably minor bugs that can be fixed and will make this a perfect service.
                Tomorrow is a 160km round tour with 15 Wpts which I plan to do without CP and just run off the iPhone as a comparison.
                Thanks again
                Charlie Spicer.
                  @Jure-Sirena-0 Thanks for the test feedback! All issues you mention are definitely known and will be solved.
                  Regarding the time / distance to the next waypoint, we would need to check if that's possible at all in CarPlay. Within CP we are way more restricted regarding what's allowed.
                  The positives are good to hear!
                  @Dae-0 I fully understand your struggle about using CarPlay!
                  The battery issue will definitely be tackled!
                  Dae 0undefined Online
                  Dae 0
                  wrote on last edited by Dae 0
                  I was discussing the CarPlay devices on the Scenic app forum and their developer informed me that WunderLINQ can be used in the Scenic app to zoom in and out when using CarPlay.
                  I am now reconsidering my decision to reconsider the CarPlay screen🤣
                  My thought process is that I was pretty much decided that CarPlay wasn’t working for me as zooming was too difficult, so I was going to buy a WunderLINQ and use a second phone for MRA. If I’m buying the WunderLINQ anyway I may as well give it a go with the Scenic app and CarPlay until/if MRA Next can also support this functionality. I’m not losing anything as I’d be buying the WunderLINQ anyway, but it saves me buying a second phone and mount for it.
                  I should say that although I talk about WunderLINQ, he said it also works with the Motive Monkey handlebar controls, so should work with the likes of BarButtons etc for non-BMW riders. (https://youtu.be/W3smaavanQQ)
                  The reason for tagging you in this post is not to simply say Scenic is better, but to make you aware that implementing Bluetooth keyboard control while still using CarPlay is possible, as we previously joked about you getting a superhero cape if you implemented it.
                  • Dae 0undefined Dae 0
                    @Dae-0 cool! Thanks for sharing 😃
                    Tempting to get that cape 😏
                    • Davide Meloncelliundefined Offline
                      Davide Meloncelli
                      hi guys, connected iPhone 12 to Honda motorcycle NT 1100, which has the same strumentation as Honda Africa Twin and the screen goes black. tried unplugging and plugging back in and out of the app, always black screen. I posted the video on the FB group. Good work
                      https://www.facebook.com/groups/mranavigationnext/permalink/805497954469695/
                      Dae 0undefined
                      Dae 0
                      Arno 0undefined
                      Arno 0
                      Davide Meloncelli
                      Andre Mullerundefined
                      Andre Muller
                      Charlie Spicer
                      Jure Sirena 0
                        supergundefined
                      • RX routes
                      • Am I using it wrong?
                        Kerry Lebelundefined
                        Kerry Lebel
                      • Spoken streetnames
                        GT JWRundefined
                        1.6k
                        Reinhard Punzundefined
                        Reinhard Punz
                        Steve Jarrellundefined
                        Steve Jarrell
                        1.4k
