  4. Discussion: Carplay / Android Auto motorcycle device tested
53 Posts 10 Posters 550 Views 1 Watching
  • Jure Sirena 0 Jure Sirena 0
    @Matt-Flaming You cannot manage routes on the fly with app. Cant you, you speak about import / export mainly. I speak about management of already preapred routes. This is where MRA and Tomtom drive are the best.
    MRA - you open route changes are saved asap - you GO
    Tomtom Drive app, you open route, change, delete, move....click sync with device, new (or old) route already awaits on device (without touching GPS device)
    This is my point
    flamingm0e Offline
    flamingm0e Offline
    flamingm0e
    @Jure-Sirena-0 said in Discussion: Carplay / Android Auto motorcycle device tested:
    Sure you can.
    You can use MRA, and send it to Explore or Drive using the phone app.
    that you almost need a laptop....because there is nothing interactive at Garmin
    Again, OPEN the route in Drive or Explore....it will send directly to the Zumo...
    But I have a feeling Garmin explore for Andrpoid is different then the one for iphone. I cant manage almost anything with app on iphone
    It's not. I use both. Really simple to sync new/updated routes.
    Jure Sirena 0 1 Reply Last reply
    • Bas Greve Offline
      Bas Greve Offline
      Bas Greve
      Zijn er al ervaringen met deze https://www.amazon.nl/Motorfiets-Navigatie-Fodsports-Waterdicht-Bluetooth/dp/B08LHDR9F1
      Dat is wel een GPS. Het lijkt me handig. Route maken op de PC. Inloggen op het device op MRA en direct vertrekken
      • flamingm0e flamingm0e
        Sure you can.
        Jure Sirena 0 Offline
        Jure Sirena 0
        wrote on last edited by Jure Sirena 0
        #45
        @Matt-Flaming Ok I get it, using 2-3 apps. Its actually what I ment.
        Nevertheless I cant edit routes in explore I only have rename and edit colours....no way to open existing route and work on it, yes for MRA of course, that I get it
        on top.......I really cant do anything with explore, except import
        flamingm0e 1 Reply Last reply
          flamingm0e Offline
          flamingm0e Offline
          flamingm0e
          I never said anything about editing in Explore....
          Edit route in MRA. Open route with Explore. It syncs with Zumo. It's literally that simple. You're making it out to be something it isn't.
          But I'm done with this conversation because you're not going to grasp what I'm saying without trying it.
            Jure Sirena 0
            @Matt-Flaming
            Oh I have zumoxt (4 bikes with them)
            Sorry not to get my point. I understand using more apps but that was not the point
              @Matt-Flaming
              flamingm0e Offline
              flamingm0e Offline
              flamingm0e
              You're not using more apps...
              Seriously, OPENING the route in Explore creates a collection. That collection AUTOMATICALLY syncs to the Zumo. So it's one step, the same as ticking a box in MyDrive. Open the route in Explore, it syncs, you have your new route right there.
              OR
              Open it in Drive, and "send to zumo"...DONE. It's not like you're editing the thing in a different application. You're just initiating the sync.
              • Jure Sirena 0 Offline
                Jure Sirena 0
                The final verdict of my problem:
                After testing 3 iphones, it was clear it only happened on mine. It is now confirmed, that everytime I connect carplay with my phone in car, it will not connect to device next time.....
                Dealer says it is ios problem and doesnt want to support the issue. It is clearly device problem, as my phone has no problem with the 2 cars we have at home. It switches between then flawlessly.
                but as soon as I connect to device with new pairing procedure, it will work for days, moths or minutes until I connect same phone to carplay in any of the cars. After that device needs new pairing OR manual activation of SPP option under the BT menu of paired phone....
                So its clearly device problem. I sold it today for 50€. Crap.
                  Tim  Thompson Offline
                  Tim Thompson
                  Not that it matters anymore...
                  But it sounded as if the common denominator was your phone.
                  I have no problem with my iPhone, CP and going back and forth between my car and this device. So far it has connected to both automatically without fail or issue.
                  Did you try the same experiment with the other iPhones? Were the other iPhones able to go between the cars and this device without issue?
                  • Tim  Thompson Tim Thompson
                    Jure Sirena 0
                    #51
                    @Tim-Thompson 1 x iphone 13 pro, 2 x iphone X (in begining of my post I ment I knew why it was happening to mine, because I was able to replicate it on all 3)
                    same issue
                      same issue
                      Tim Thompson
                      same issue
                      Oh... So you are saying that all 3 iPhones tested had troubles going back and forth between your cars and this device? All 3 phones would connect to your 2 cars without issue, but all 3 phones would fail to connect to the device after being connected to one of your cars?
                      If I understood that correctly... Don't know what to tell ya. Doesn't matter anyway... You've already made the problem go away... Just not in the way one might prefer.
                        same issue
                        Jure Sirena 0
                        @Tim-Thompson yes thats it.
                        Vlad Popovici 0
                        Vlad Popovici 0
                        Bas Greve
                        Bas Greve
                        flamingm0e
                        flamingm0e
                        Bart 4
                        Bart 4
                        Jure Sirena 0
                        Jure Sirena 0
                        Tim  Thompson
                        Tim Thompson
                          1.3k
                        • New update 5.2.1
                        • die selbe Route/Strecke zurückfahren, wie vorgehen bei Generierung der Navi Daten
                        • Hiding home address / waypoint for shared routes
                        • Points of interest
