  4. Next closes immediatly when starting a planned route
problemandroid 12huawei p30 pro
32 Posts 10 Posters 362 Views
  • Corjan Meijerink Offline
    Strange. I would suggest uninstalling the app completely and clearing cache / data from Settings > Apps > MyRoute-app Mobile too.
    That might help! Especially since this is the first report of such issues, I am a bit unsure of what the issue can be.
      @Corjan-Meijerink, A complete re-install I tried while you were typing that request 😉 But it did not make a change (on both phones). Now I also followed your suggestion about the cache-data, and user data, and also that makes no difference...
      • Is there some way to get diagnostic data to you?
      • can you PM me with details of a known working account? Maybe I can test if it's account related that way.
        @Con-Hennekens I’ll contact you personally tomorrow! 🙂
          @Corjan-Meijerink, I need to withdraw some earlier findings because they were incorrect:
          I stated that my tablet did function with navigating, but later I found that it was navigating the "follow the line" method, not using Next's turn by turn.
          Also I stated that a direct-to-destination route was navigatable (is that a word?), but also that one tricked me into the "follow the line" method. The difference between "follow the line" and "Turn by Turn" is not very clear. The icon that is used at A is identical to the icon used for a turn by turn route planned in the planner. I was thinking the icon for B would have something to do with multiple route suggestions, but apparently it does not.
          @Corjan-Meijerink, you are welcome to contact me personally.
            @Con-Hennekens I agree that the icons used can be slightly confusing. I'll make sure this is improved in the next update 🙂
            We want the users to be able to use the Mobile app as they know and also allow Navigation Next users to use the Navigation. The current choice does work but doesn't provide the best experience.
              @Corjan-Meijerink, I completely agree with that! I think the most logical way is to improve the Next icons, not the Planner icons. But most important right now (for me that is...) is to find a solution for the crashing app. It looks like that happens as soon as any Next turn-by-turn function gets called.
              • MyRoute-app community MyRoute-app community moved this topic from [Beta] The MyRoute-app on
              • Tim  Thompson Offline
                Tim Thompson
                Just adding my 2 cents here...
                I've experienced this problem as well. Once it manifests, it seems to continue to fail (closes immediately when starting navigation). My current work-around is to open a different route and start it. This seems to work consistently. I then go back and select the original route and open/start it. For whatever reason, this seems to work.
                Edit...
                Just to clarify what I mean by starting a route...
                If I get past that point - then all is good. But at times it is an "if".
                Edit^2...
                Also noted it closing unexpectedly with choosing to edit (pencil icon) from this screen.
                • Tim  Thompson Tim Thompson
                  Edit...
                  Edit^2...
                  @Tim-Thompson, yes, that makes us two of a kind 😉 Bevause it seems to be a very rare problem.
                  I already told @Corjan-Meijerink, this in a support chat, in my experience once my first route-load works then, without quitting the app, I can load all thinkabel routes. But when the first load fails, I can't load any route until perhaps by force-closing the app.
                    This will be investigated coming week! 🙂
                      @Corjan-Meijerink, I have full confidence 😉 I didn't mean to disturb your weekend!
                        @Con-Hennekens You haven’t at all 🙂 No worries!
                        • Hans Kremers Offline
                          Hans Kremers
                          For what it ist worth, I'm seeing the same behaviour in a Huawei P20 Pro, Android 10
                          After selecting and starting the navigation, the screen goes Black and the Desktop appears
                          I tried several routes, all with the same result.
                          Starting navigation with the same routes in a Lenovo P11 Pro (Android 12) works fine
                          Regards,
                          Hans
                          • Hans Kremers Hans Kremers
                            Regards,
                            Hans
                            @Hans-Kremers Thanks! Tomorrow - Thursday are scheduled for app development so we’ll start the investigation shortly! 🙂
                            ASPK 1 Reply Last reply
                              ASPK Offline
                              ASPK Offline
                              ASPK
                              Je rencontre exactement le même problème avec mon Samsung S20FE.
                              Si je démarre Next, je charge un itinéraire de la bibliothèque, je lance la navigation et l'application se ferme. Si je redémarre une seconde fois, çà fonctionne et je peux ouvrir tous les autres itinéraires sans soucis.
                                Tim Thompson
                                I tried clearing that app cache and then retried starting the route. That seemed to work. Don't know if it was a coincidence. But for what it's worth.
                                  Tim Thompson
                                  #22
                                  I've upgraded to the latest beta version 3.2.5 - 146. I uninstalled it and reinstalled. Still having the stability issues. In fact, they may have gotten worse. It's now crashing occasionally when going to the menu (upper left) and selecting "Routes". Tried clearing the app cache again. That doesn't seem to be helping (must have been a coincidence before).
                                  In case it helps...
                                  • Pixel 5a
                                  • Android Version 13, Build number TP1A.221105.002
                                  • MRA Beta Version 3.2.5 - 146
                                    In case it helps...
                                    • Pixel 5a
                                    @Tim-Thompson Remarkable how this very annoying problem exists for a limited amount of users 😞 We will continue researching this coming week! The most annoying part is that we never experienced this issue on any of our Android test devices. We will keep you posted about any progress!
                                      Tim Thompson
                                      Another thing I noted... If I really get stuck, I try clearing the app storage. Kind of annoying... But one must do what one must do. So far, this step has worked to get past the issue. However, it may as well be a coincidence too.
                                      Anyway... For what it's worth.
                                        @Tim-Thompson Indeed, for what it is worth 😉 The issue needs to be resolved by us. It's as simple as that!
                                        Tim  Thompson b0hd1 2 Replies Last reply
                                          Tim Thompson
                                          #26
                                          Just a thought. Is it possible to implement logging to help troubleshooting/capture the issue?
                                          Michel van Hagen MRA-Founder
                                          ASPK
                                          ASPK
                                          Mike Whitwam
                                          Mike Whitwam
                                          Koen VH
                                          Koen VH
                                          Hans Kremers
                                          Hans Kremers
                                          Tim  Thompson
                                          Tim Thompson
                                          Andrew Melton
                                          Andrew Melton
                                          • Export to BMW CRN
                                          • Nieuwe gebruiker uit Groningen
                                            Ron 0 0
                                            Ron 0 0
                                          • Update 5.2.2 - Quick fix
                                            TomOnTour
                                            TomOnTour
                                          • Berekende route tijd
                                          • Suggestion about making routes visible in a folder
                                          • Did somebody see 5.2.2 (489) on android Yet!
                                          • Gidday from New Zealand.
                                            Bull Tahr
                                            Bull Tahr
