  3. GPX 1.1 or 1.2
GPX 1.1 or 1.2
27 Posts 12 Posters 15.3k Views 3 Watching
  • Drabslab Drabslab
    @Carl-Lee said in GPX 1.1 or 1.2:
    Anyway, 1.1 or 1.2?
    Actually, I think that GPX 1.2 does not exist, at least not as an official standard.The current version of the standard appears to be GPX 1.1 released in 2004. (https://www.topografix.com/gpx.asp). The development of that standard seems to have stopped? But the experts of MR can tell a lot more about that probably.
    GPX 1.2 seems to be an MRA or Garmin interpretation of GPX 1.1 that is adding functionality not able to achieve with 1.1?
    Carl Lee
    Carl Lee
    Carl Lee
    @Drabslab fair enough, no reason to doubt your specifics but it's there and works perfectly (so far) for what I want it to do which is send me on the exact route I planned and only show me the (via) points I select.
    Drabslab 1 Reply Last reply
    • Carl Lee Carl Lee
      I am not saying it is a bad format or that it has no advantages, just that it is not part of the official standard.
      Moving away from the standard may lead to long term problems. But, when the standard does not evolving anymore, a company like MRA has no other option it seems
      • Steve Lynch Steve Lynch
        @Des-Sheil-0
        In my experience using the Routelab directly with Garmin Drive causes issues on my iPad Pro.
        Using MyRoute-App Mobile works flawlessly on iOS and Android.
        See the screenshots I posted above that show each stage of transferring a route to the Garmin XT using MyRoute-App Mobile.
        Don Stauffer
        Don Stauffer
        Don Stauffer
        @Steve-Lynch I don't think I can help you. My only issue ever was over 1 year ago, there was a release of the Drive App that failed to download to the Zumo. Since the update (V4.19.37) everything has been fine.
        Best of luck!
        Don Stauffer
        • Don Stauffer Don Stauffer
          Best of luck!
          Don Stauffer
          Steve Lynch
          Steve Lynch
          Steve Lynch
          @Don-Stauffer
          No Help required here the XT is faultless for me.
          AXMRDR 1 Reply Last reply
            @Don-Stauffer
            AXMRDR
            AXMRDR
            AXMRDR
            wrote on last edited by AXMRDR
            #25
            • HighPeakRider
              HighPeakRider
              HighPeakRider
              I know this topic is very old, not sure if its been discussed again.
              I'm not technically knowledgeable about GPX, but
              If I use 1.1 transferred to the Zumo via Drive it saves it both as a track and a route. Which seems a good option.
              However 1.2 only transfers as a route?
              No idea why but does the change which is the better format if you wish to follow the exact route as planned?
              I'm usually happed to just follow a line as long as I'm taken the correct way.
                @Rob-Wilkie After a lot of work, I gave up on Basecamp and purchased a lifetime Gold MRA membership. I have the Garmin Drive app on my Android phone already, and it has been linked to my Zumo GPS.
                My workflow to load a route into the Garmin Zumo XT is like this:
                1. Build the route using MRA, usually from my desktop.
                2. Open the route on my Android phone using the MRA mobile app.
                3. Select the Download button from the MRA app on the phone, I have been using .gpx 1.1 format.
                4. A pop up announces 'File has been saved!' and shows a link for 'Export'.
                5. Touching 'Export' automatically opens the Garmin Drive app, and asks 'Would you like to send it to your Garmin device?'
                6. The route then downloads to the Zumo XT. On the Zumo, choose 'Apps', then 'Trip Planner.' Your new route will be visible there.
                It sounds more complicated than it is, and requires no cable connection.
                With the exception of a flawed release of the Drive app last year, this process has been very reliable and dependable.
                -KTM-Don
                Em Pir
                Em Pir
                Em Pir
                @Don-Stauffer This is my first forum post. I HAD to find out how to use the forum to THANK YOU Don for giving the steps to easily and successfully get a .gpx from a website to my Zumo XT!!
                I do, though, have to (humbly) add that I had to tap [Share] in the MRA app after tapping [Download]..
                Don Stauffer
                Don Stauffer
                Carl Lee
                Carl Lee
                artbone
                artbone
                JWeetje
                JWeetje
                HighPeakRider
                HighPeakRider
                AXMRDR
                AXMRDR
                Steve Lynch
                Steve Lynch
                Em Pir
                Em Pir
                Rob Wilkie
                Rob Wilkie
                Des Sheil 0
                Des Sheil 0
                  Jeroen ekkel c
                  Jeroen ekkel c
                • Xpert overlay not clear
                  JP d
                  JP d
                • Trains like Ferries?
                  Solo1138
                  Solo1138
                  Hanza 0
                  Hanza 0
                • Vermijdingsopties is wat verwarrend
                  Eric Bovelander
                  Eric Bovelander
