  3. Route resets to beginning when nav app device turned off
15 Posts 5 Posters 2.1k Views
  • Mark Jones 0undefined Offline
    Mark Jones 0
    I have the nav app installed on an Android head unit and this works very well.
    However it has one really annoying behavior.
    When the ignition is turned off, and back on, the app remembers the route in use and continues navigating it. However it always defaults back to the beginning and trys to go back to the first waypoint.
    Is this the expected behaviour and is there a way to make it continue where it left off?
    Con Hennekensundefined Nick Carthewundefined 2 Replies Last reply
    • Mark Jones 0undefined Mark Jones 0
      @mark-jones-0, I have been complaining about this behaviour some time ago on this forum too. The setting to start at the closest waypoint does not "stick", not even after loading a new route. I hope this will be addresses in next years new version.
      I am curious about the Android head-unit you are using! Can you tell us something about that?
      Thanks!
      Mark Jones 0undefined 1 Reply Last reply
        @mark-jones-0 I use MRA Navigation on my iPhone and what I do if I stop for any length of time is pause the navigation and it always starts off from where it was paused from. Maybe try pausing the app on your Android phone when you stop.
        Mopetenpitundefined 1 Reply Last reply
          Mopetenpitundefined Online
          Mopetenpit
          @nick-carthew how do you pause the navigation app?
          Peter
          • Mopetenpitundefined Mopetenpit
            Peter
            @mopetenpit My mistake, I always use the tracking when navigating, it is the tracking that I pause.
              Mopetenpit
              @nick-carthew
              OK, I thought I had overlooked a new feature👍
                @nick-carthew
                Mark Jones 0
                @mopetenpit said in Route resets to beginning when nav app device turned off:
                @nick-carthew
                I think you have, it's a button next to skip waypoint. Pause
                  Thanks!
                  Mark Jones 0
                  @con-hennekens said in Route resets to beginning when nav app device turned off:
                  Thanks!
                  It's made by Joying, let's you run all Android apps on the headunit and has digital out to connect to the gap on my car audio install
                  Steve Lynchundefined Con Hennekensundefined 2 Replies Last reply
                    Thanks!
                    Steve Lynchundefined Offline
                    Steve Lynch
                    @mark-jones-0
                    Couldn’t you use the Skip function when you turn the Android Head back on?
                      @mark-jones-0
                      Mark Jones 0
                      @steve-lynch that's what I'm doing, but requires you to remember exactly what waypoint your at and potentially skip a lot of them. It works but it's a band aid that I'm not sure should be necessary
                        Steve Lynch
                        @mark-jones-0
                        Fair point!
                          @nick-carthew
                          Mopetenpit
                          @mark-jones-0 said in Route resets to beginning when nav app device turned off:
                          also in the iOS version?
                          Nick Carthewundefined Mark Jones 0undefined 2 Replies Last reply
                            No, not on the IOS app.
                              Mark Jones 0
                              @mopetenpit ah that's a good point, not sure I use android
                                Thanks!
                                Thanks!
                                Oh, I know Joying indeed, but I falsely assumed you were talking about a motorcycle head-unit 😉
                                Mopetenpitundefined
                                Mopetenpit
                                Mark Jones 0
                                Steve Lynch
                                  Axel Härtlundefined
                                  Axel Härtl
                                  Massimo Cardoneundefined
                                  Massimo Cardone
                                  2.6k
                                  Aiello antoninoundefined
                                  2.8k
                                  Jan Weerheimundefined
                                  Jan Weerheim
                                • Doe ik iets verkeerd of...
                                  Michel 71 0undefined
                                  Michel 71 0
