  3. MRA Navigation and downloaded maps.
54 Posts 10 Posters 37.2k Views 2 Watching
  • PAD 0 PAD 0
    @con-hennekens In answer to your opening question, yes! As long as the issues with Navigation persist.
    Maybe the app works for you (using Android, if I’m not mistaken?). However, my direct experience of having used it on a day to day basis from the beginning of April to the end of October last year was very far from being reliable and an effective sat nav replacement (and please do bear in mind that I very much do want Navigation to be just that). In fact, out of the dozens of times I used the app only twice did it not misbehave (using it even when I knew precisely where I was going as a means of testing performance after a very disappointing introduction and frequent contact with the support team). And the misbehaviour came in ever changing ways.
    The last straw came in Dublin where Navigation decided my chosen route was inappropriate and that I should do a grand tour of the city’s south side rather than follow it. After tying itself in knots, it crashed. There were no road closures to cause issues and I was using offline mode anyway. Seasonal closures were disabled, all waypoints accurately and legitimately placed, etc, etc. Luckily, I know Dublin very well indeed so I was able to ignore the craziness. But out of interest I switched on my ageing but trusty Zūmo 390 (I fabricated a mount that holds phone and sat nav side by side so that I could compare the performance of the two or switch easily to Garmin when Navigation almost invariably flipped its lid) to check whether it had problems with the same route. It picked it up effortlessly and ‘guided’ me to Dublin Port faultlessly… I think that speaks volumes as to those marketing claims.
    @pad-0, I have a Zumo 390 too. I have not touched in in three years, since using Navigation. And yes, every now and then I have to pull over to give it a kick, but probably less often than with my zumo, that is far less handy considering skipping waypoints and things like that. It is largely a matter of perspective I guess.
    PAD 0 1 Reply Last reply
      PAD 0
      PAD 0
      PAD 0
      wrote on last edited by PAD 0
      #27
      @con-hennekens Truly, I am delighted to learn that you haven’t needed to use your Garmin for so long. It gives a glimmer of hope! Perhaps that perspective is influenced by app version, Android vs iOS?
      For instance (and pertinently so, I think?) in the iOS app customers get no such highlighting of recently used routes as indicated in your post, above. This wasn’t covered in a recent discussion of using Navigation offline. It strikes me that this significant difference between app versions (one of a number of such) might help to explain our obviously very different user experiences when accessing, or trying to access, routes offline?
      From reading various forum conversations, I have wondered occasionally why the two app versions do differ in various ways? It seems a very odd way to be going about things?
      • PAD 0 PAD 0
        #28
        @pad-0 said in MRA Navigation and downloaded maps.:
        @con-hennekens said in MRA Navigation and downloaded maps.:
        ...ago, and I can just open it up and start navigating it in flight mode.
        To clarify some things: I myself did not see this highlighting before until Con pointed one very significant setting out: the Airplane mode of the phone. I was only able to show the highlighted routes (and with that my previuosly downloaded routes in Offline mode) after I've turned on Airplane mode. Even with the Nav app in Offline mode, but with 4G enabled, the app itself seems to be still in 'online mode' and therefore does not show the actually downloaded routes as highlighted and the rest greyed out). I usually don't drive in offline mode so I have no experience whether the nav actually works offline, when set in offline mode, but with 4G still enabled. @Con-Hennekens Can you perhaps elaborate on this set of conditions?
          PAD 0
          PAD 0
          PAD 0
          #29
          @stefanhummelink To clarify further, can you confirm that the above relates to your using an Android device? Because with my iOS apps, use of offline mode in conjunction with airplane mode results in wall to wall buffering! Just offline mode with mobile data and wifi off works for opening recent routes when in offline mode. That highlighting/greying out doesn’t happen under any circumstances in the iOS version and it would be very, very handy if it did.
          Again, I find myself wondering why the difference(s) between iOS and Android versions? I’d be interested and appreciative to see an explanation/justification.
          Steve Lynch Stefan Hummelink 2 Replies Last reply
          • PAD 0 PAD 0
            Steve Lynch
            Steve Lynch
            Steve Lynch
            #30
            @pad-0
            I occasionally use MRA Navigation now and then as its generally a back up.
            I always have the Zumo XT running as well however, but I have found the Android version to be stable for me with the odd issue now and then.
            I only use Shaping points, never Via Points on any of my routes.
            Yes, the highlighted and un-highlighted routes are on the Android version only. ( I have an old iPhone 6 Plus without a sim).
            Clicking on a un-highlighted route gives this pop up.
            Clicking Ok clears it and I can still select the highlighted routes.
            Android Settings.
            • PAD 0 PAD 0
              Yes indeed, I have an Android phone. Oneplus 6.
              • Tom Cat
                Tom Cat
                Tom Cat
                I finally got a chance to put it through a decent test today. 150 miles over about 4 hours and it worked better than expected. I left it in online mode the whole time. The only complaint I had is that it seems to be about 100 feet or so behind in navigation. By this I mean when approaching a turn by the time it announced the turn I was already on it and it was too late to turn. Honestly, once I realized this I just paid closer attention to the earlier routing notifications when I was approaching a turn such as "turn left in a quarter of a mile."
                One other thing I ran into was it not updating the distance to one of my turns upon approach. To be fair this was after a lunch stop where I left the app open and running in the background so I'm not sure if that had anything to do with it. I noticed the distance to the next turn was stuck at 3300 ft and was not updating. Once I was at the turn it said "turn right" but at that point, it was too late and I was already passing the turn. Once it rerouted everything was fine for the rest f the ride. So I am not sure if this was just a memory issue with it running in the background during my hour lunch stop or what.
                Rerouting worked much better than on my TomTom. During my ride, I came across a closed road due to a collapsed bridge and it instantly rerouted like a champ. It also rerouted my missed turns very well.
                All-in-all I was pleased with how it worked. For my next ride I will try using offline mode to test that out.
                Just for clarification I was using a Pixel 5a and created my ride in Routeplanner using the HERE map.
                Mopetenpit 1 Reply Last reply
                • Steve Lynch Steve Lynch
                  @pad-0
                  Android Settings.
                  @steve-lynch said in MRA Navigation and downloaded maps.:
                  Ouch, that of course I did not know, and I agree with @PAD-0 that it is very strange that the IOS and Android app differ in this (and probably more) respect(s).
                  I can also confirm that the highlighting ONLY happens when no internet-connection is available. The Off-Line mode has to do with maps and traffic-info, not with the loading of routes.
                  Do you mean that Navigation keeps saying "calculating"? I get that often in on-line as well as off-line mode. But it disappears shortly after going on route. This is certainly one of the quirks...
                  • Tom Cat Tom Cat
                    Mopetenpit
                    Mopetenpit
                    Mopetenpit
                    @tom-cat said in MRA Navigation and downloaded maps.:
                    Also had this phenomenon several times, not often, but every now and then. I'm writing this to remind the MRA team of the problem as well. I thought it was just an isolated case with my iPhone....
                    Peter
                      PAD 0
                      PAD 0
                      PAD 0
                      #35
                      @con-hennekens The buffering I experience is endless and with no ‘calculating’ message. When I first encountered it, many months ago, I did leave the phone to chew it over for a long time to see did it resolve but I suspect it might still be at it now had I left it! If the buffering was several seconds, or even a minute or two, I could live with that, albeit reluctantly if towards the longer time.
                      • Mopetenpit Mopetenpit
                        Peter
                        PAD 0
                        PAD 0
                        PAD 0
                        @mopetenpit I am shocked at how lax MRA continue to be over the late voice guidance. It is surely only a matter of time before an accident is caused, e.g. due to sudden braking or performing a ‘U’ turn, etc. Were I an executive of the company I would be very concerned - not only for my customers, but also of being held culpable in the event of death or serious injury.
                        I can’t imagine why this occurs. It’s not something I’ve ever experienced with Garmin sat navs though.
                        I wonder is this another problem with the iOS app only , or do users of the Android version of Navigation experience it too? (I have experienced it while using both iPhone and iPad - the latter being a wifi only model and running with a Garmin GLO2 GPS/GLONASS unit which I believe is far superior to the onboard Apple chip by some margin in terms of speed, signal and accuracy.)
                        • PAD 0 PAD 0
                          #37
                          Unfortunately I find the voice guidance being too late for my liking all the time, and sometimes like mentioned by @Mopetenpit extremely late on my Android OnePlus 6 as well! Like, turns being guided while already turning. Lol. I do however look at my screen considerable often to get a glimpse of the road curves ahead, so most of the time I find it not to be any practical problem, however, the app should just not have such quirks.
                            PAD 0
                            PAD 0
                            PAD 0
                            @stefanhummelink Thank you for confirming that. Had I paid more attention I’d have spotted that @Tom-Cat mentioned his use of a Pixel 5a. I agree concerning directions being generally later than I would prefer. And I do find they are far too late quite frequently - occasionally after I have turned!
                            On the matter of looking at screens while on the move, surely this is generally undesirable from a safety perspective and both hardware and software need to be designed to minimise the need to?
                            I’m no ‘purist’ here and willingly acknowledge that it’s a reasonable thing to do sometimes, e.g. though I try to avoid UK and Irish motorways as much as is practical, I find junction layout views very useful sometimes, and I prefer to rely on sat nav/app speed readings rather than the speedometer, particularly on my ageing VFR800.
                            Generally, though, and certainly on my preferred road types, I think all the hazards and developing situations around me is where my attention needs to be, not forced into screen gazing due to badly timed voice guidance.
                            Stefan Hummelink Con Hennekens 2 Replies Last reply
                            • PAD 0 PAD 0
                              #39
                              I see where you're coming from, however the 😈 is in the details here. My smartphone is located in the middle of my handlebar such, that looking at my Speedo equals looking at my phone's screen. That being said, when one looks continuously on their Speedo, you point is stil valid, so it makes sense for me to mention that I purposely look at my screen not due to the app malfunctioning on its basics(like you suggest it may be due to the late voice guidance), but rather because I provides me with information regarding the curve of the upcoming road. I use the app in landscape 3d, so I can see quite far ahead. This however is completely unnecessary in urban conditions, so that's why I merely ride like this on intended curvy roads. Twisties as we know them. 😃
                              I do look around extensively. In the Netherlands during the mandatory driving lessons to acquire the license, we are trained to be on the lookout for danger all around us. Every car driver is a hired assassin haha! 🤭 So imho for me, I'm not necessarily creating additional risks for myself, since I'm aware of the actual potential dangers ahead. 😃
                              Regarding the hardware or software limiting this possibility at all: no no no. I'm no fan of some software or hardware prohibiting a certain use. I'd to like to keep stuff in my own hands. 😃
                                PAD 0
                                PAD 0
                                PAD 0
                                @stefanhummelink Sure, I get where you’re coming from, too. My comments were meant in general and not directed at you. Sounds like we have similarly located devices and, yes, for those functions that require just a glance and emulate vehicle instruments, what harm?
                                I didn’t intend to imply that certain functions should be prevented by design, not my bag at all! Rather, I mean that effective design and function should render all but essential screen gazing unnecessary. I believe that any disabling features should be discretionary and firmly under user control, such as those found on Garmin (some/all?) sat navs.
                                We do differ on the use of screens to assess the road. Long ago, I encountered the term ‘the map is not the territory’. I think this is equally pertinent to sat nav views. My preference is to keep my head up and my eyes on the road but, hey, that’s just me. We ride our own ride, yes?
                                • PAD 0 PAD 0
                                  Steve Lynch
                                  Steve Lynch
                                  Steve Lynch
                                  #41
                                  @pad-0
                                  I agree that Android MRA Navigation is also laggy when using voice navigation. Basically I turn it off.
                                  Haven’t noticed any lag in the actual GPS location however.
                                  I took a trip to Loomies Cafe in Arundel yesterday.
                                  My plan was to take the iPhone 6 Plus as well as the Zumo XT.
                                  Whilst prepping the routes with WiFi on to ensure they were available in MRA NavigationI had a strange thing happen.
                                  When hitting the exit button it was actually shutting the Navigation App down not going back to the Route page.
                                  Had to uninstall-reinstall the App.
                                  Didn’t bother taking the iPhone with me. 😳
                                  Regarding keeping eyes on the road the Zumo XT position on the Tiger 900 Rally Pro is perfect for a quick glance.
                                    @drabslab
                                    Ik begreep dat de ontwikkeling van Navigation werd geoutsourced. Is dat misgelopen, en gaan jullie het dan toch zelf doen? Misschien goed om eens iets in het forum te publiceren daar over. Sommige gebruikers zijn ongeduldig 😉
                                    Beantwoorden
                                    1 w
                                    Topfan
                                    Con Hennekens Eens, duidelijkere communicatie over de status en aanpak van Navigation. De recente enquête over Nav Next heeft het absoluut niet duidelijker gemaakt.
                                    Beantwoorden
                                    1 w
                                    Auteur
                                    MyRoute-app
                                    Na MRA Mobile gaan we aan Navigation Next werken. Hier is alvast een preview en visie: https://blog-myrouteapp.com/navigating-via-mra-navigation/
                                    Navigeren via MRA Navigation...
                                    BLOG-MYROUTEAPP.COM
                                    Beantwoorden
                                    1 w
                                    Topfan
                                    MyRoute-app Maar wat ik mij tijdens de enquête over next ook al afvroeg: in de huidige nav app zitten nog heel veel zaken die verbeterd of opgelost moeten worden, en nu komt er een nieuwe MRA Nav versie, genaamd Next. Dit komt ook op mij als trouwe MRA gebruiker van beide apps, een beetje vreemd over. Er lijkt nu, zeker ook op basis van alle activiteit op het forum over MRA Nav, al resourcestekort te zijn om de bestaande Nav app te verbeteren en bugfoxes door te voeren, laat staan een volledig nieuwe app te ontwikkelen? Betekent de Next variant dat er aan de huidige Nav niets meer verbeterd wordt?
                                    Beantwoorden
                                    1 w
                                    Stefan Hummelink, ik lees dat Navigation gebruikers gewoon overstappen naar Next. Dus waarom zou je de oude app dan nog willen gebruiken?
                                    Beantwoorden
                                    1 w
                                    Topfan
                                    Con Hennekens "gebruik kunnen maken van de nieuwe app, dit is een keiharde garantie!" Dat doet suggereren dat beide apps zullen blijven bestaan. Dat vind ik gewoon merkwaardig. In de eerdere communicatie over next via die enquête, werd ook de indruk gewekt dat beide apps parallel zullen draaien. Op het forum is hier ook kritisch op gereageerd. Natuurlijk zal ik ook gewoon gebruiken wat gangbaar is, maar het feit blijft dat het nu al zeer lastig blijkt bugfixes en/of verbeteringen door te voeren op Nav, dus het ontwikkelen van een geheel nieuwe variant lijkt echt een bridge too far. Natuurlijk kan dat wel, mits geaccepteerd wordt dat de huidige app blijft zoals die is.
                                    De vraag "waarom moeten er überhaupt twee versies blijven bestaan" is net zo legitiem, toch?
                                    Beantwoorden
                                    1 wBewerkt
                                    Stefan Hummelink, zeker, maar net zoals jij zie ik niet in waarom je 2 apps met dezelfde functie zou gaan onderhouden. Dat heeft alleen zin als de nieuwe versie functies ontbeert die de oude wel heeft. Ook vind ik een overgangsjaar wel zinvol, zodat je bij gebleken onoverkomelijke bugs kunt terugvallen op de oude app. Dat de nieuwe uiteindelijk de oude overbodig maakt lijkt me evident.
                                    Beantwoorden
                                    1 w
                                    Auteur
                                    MyRoute-app
                                    Er komt een nieuwe navigatie app die op termijn huidige navigatie app gaat vervangen. Omdat we de app in een nieuwe taal gaan schrijven is dat efficiënter. De huidige app wordt tot die tijd gewoon onderhouden. We zijn nu het ontwerp aan het uitschrijven op basis van de onderzoeksresultaten.
                                    Beantwoorden
                                    1 wBewerkt
                                    Topfan
                                    MyRoute-app "onderhouden" betekent ook nog vernieuwingen of alleen bugfixes?
                                    Beantwoorden
                                    1 w
                                    Stefan Hummelink, nu we weten dat de nieuwe app de oude gaat vervangen, zie ik liever dat ze die effort can vernieuwing steken in de nieuwe app. Ik ben wel reuze benieuwd naar een ETA 😉
                                    Beantwoorden
                                    1 w
                                    Topfan
                                    Con Hennekens Nou... Als ETA uitkomt op ca 2 jaar, dan zie ik toch nog wel graag verbeteringen aan de huidige versie doorgevoerd worden. 🤭
                                    Beantwoorden
                                    1 w
                                    Stefan Hummelink, dat is zeker inderdaad! Laten we hopen dat er wat vaart in komt.
                                    Beantwoorden
                                    1 w
                                    So, there's more info on MRA Navigation Next and what it means for the current app in a new blog post: https://blog.myrouteapp.com/mra-navigation-next/
                                      @herko-ter-horst Woa: " In fact, we are also going to work hard with improvements with the current navigation app, such as a folder structure for your routes." 😄 We've been heard!
                                      • PAD 0 PAD 0
                                        #44
                                        Of course attention needs to be focused on the road. But having a glance on the display at a self chosen moment, and thus knowing (without auditive assistance) where to go helps A LOT in avoiding dangerous situations. I have been running my Garmins for many years without headset in my helmet, and thus driving on the screen only. In my opinion a glimpse on your screen tells a lot more than a 1000 words.
                                        But I share the thought that the spoken assistance is sometimes a bit late. It has never happened to me AFTER the turn though. And mostly it has been said already a few 100mtres earlier.
                                        The words are however often not spoken clearly. Often I hear in "150 metre" the "One Hundred" and the "fifty" spoken simultaneously. At first I thought it was a phone problem, but my new phone does the same.
                                        Stefan Hummelink PAD 0 2 Replies Last reply
                                          This happens to me quite often as well!
                                          Mopetenpit
                                          Mopetenpit
                                          Steve Lynch
                                          Steve Lynch
                                          Tom Cat
                                          Tom Cat
                                          PAD 0
                                          PAD 0
                                            martin-phogel.de
                                            martin-phogel.de
                                            12.0k
                                          • Issues on one-way streets when reversing routes
                                          • Route line is not easy to follow on map
                                          • F004 MRA Navigation Error
                                          • Probleem met eigen Stay
                                            Albert van den Elsen
                                          • POI functie 'strict'
