  4. Petrol stations
Petrol stations
27 Posts 9 Posters 15.1k Views 5 Watching
    If you have a list of Fuel stations in your POI library, select the profile icon and the fuel POIs will be visible in all of your routes when planning and when you are navigating.
    @Nick-Carthew said in Petrol stations:
    @Nick-Carthew so this - what you suggested - is only possible
    • with a POI list, which you uploaded in your POI library?
    • AND only with fuel stations?
    I tried it with only activated fuel station from App internal POI list, this wasn't working.
    • Guzzist Guzzist
      #22
      @Guzzist You can only select the profile icon from your own POI library. The profile icon looks like a head and shoulders. Any list of POIs that you have added to your library can be made visible while navigating.
      You must select the profile icon to see the POIs.
      Guzzist 1 Reply Last reply
        @Nick-Carthew thank you very much!
        Just at the moment when I read your explanation, I remembered that I had once read it somewhere. But at the time I didn't really realise the benefit. Now it is clear to me, and I find it valuable.
        For example, I can show all the Alpine passes that I have as a list in my library when navigating. Then I could spontaneously change my journey on the way because I see a pass nearby on the map. I can then simply add it to my route as an additional waypoint by pressing and holding on it.
        How cool is that 😎
          @Spili said in Petrol stations:
          There are restriction on AA/CP side?
          I do not think so because my screenshots are from Sygic running on Android Auto.
          Maybe MRA has any limitations we do not know?
          Yes there are restrictions, I don't think so, I know so.
          What reason do you think MRA would have to cripple the AA/CP interface like that?
          Your screenshot from Sygic clearly shows it has much less clutter by buttons and info tiles on it's screen. They clearly choose different things to show than MRA did, but they cope with the same limitations.
          @Con-Hennekens said in Petrol stations:
          thanks to explane little more. still in MRA Next it self the petrol station info is switched with second exit or turn. is that not a option ? that uses no more space on screen. just a question... maybe it is not a option.
            @Spili, I am sorry, in my earlier comment I left out that you are using an AA/CP device, obviously noticable in your screenshots... I believe the tile I mentioned is indeed not visible on AA/CP devices, because of restrictions bij Google and Apple. There is a limit to the available information on such devices, to keep them from being a distraction. MRA choose other info and buttons to be visible. Maybe something can be changed about that in the future.
            Stop saying that ! If MRA does not have functions that other apps (Sygic, TomTomGo) have, like showing the next gas station on Android Auto, that is not because of limitations. Limitations applies to all not only to MRA, so in this case, its a function that is just not implemented in MRA !
            Adrian
            • Adrian Avram Adrian Avram
              @Adrian-Avram said in Petrol stations:
              Stop saying that !
              I will not be shut up by you...
              In the pictures @Spili shared you can clearly see the limitations in action. They may have fuel station icons, but where are the zoom buttons, the skip waypoint button, the menu button? They just chose differently than the MRA developers. If you know better I'll wait until your own navigation app is released. It must be a really great one so I want it! 😉
              @Bouke-Ent said in Petrol stations:
              That could perhaps be, but the third highlight in the screenshot above indicates limitations for that method too. turning information could trigger the drivers attention to stay fixed on it until the info he needs comes by. Not ideal...
                This is getting nowhere, I'm locking the thread.
                Limitations apply to CarPlay / Android Auto.
                Limitations do not mean it isn't possible.
                We decided to add different features using the limited available space.
                Will we add more functionalities within the constraints? Most probably!
                richard 3v
                richard 3v
                Spili
                Spili
                • test Myroute APP
                  1.9k
                • How to plan correctly
                  Christian Feurstein
                  Christian Feurstein
                  Jörg Neudert
                  Jörg Neudert
                  LE DIZES Freddy
                  LE DIZES Freddy
                  8.0k
                • Tour results and a question
