  4. Export also as Excel
7 Posts 4 Posters 1.8k Views 3 Watching
  • Tom Balmerundefined Offline
    Tom Balmer
    For planning longer routes, it would be practical if I could export the number of the point, the total kilometers and total hours as well as the kilometers and hours from point to point in an Excel (with one column each! This does not work at all via Pdf!). In my opinion, this would allow me to explore daily kilometers and travel times more quickly.
    • Reinhard-32undefined Offline
      Reinhard-32
      You can use: "Save as PDF"
      Kindly regards
      Reinhard
      Montana 700i and Mac
        Tom Balmer
        wrote on last edited by Tom Balmer
        Yes, I know, but I would like to calculate daily distances and duration. And I know, there is the feature of myroute to calculate the distance and duration between two points. It would be much more convenient to do this in Excel than to write down every single calculation of myroute somewhere.
          Travellexxieundefined Offline
          Click on the heighticon on the left, than you see on your right a graphic. When you hoover with your mouse over that graphic, you see, in a little box, distance and height and this is also shown in the route itself.
            Tom Balmer
            That is indeed a nice feature. But I just wanted to suggest that in addition to the pdf export, an Excel export of the numbers mentioned would also be a nice feature.
            • Tom Balmerundefined Tom Balmer
              @Tom-Balmer being an Excel-addict, you have my vote 😂
              Maybe you can convert a pdf to a csv, there are many tools on the internet, you can try.
                @Tom-Balmer
                • The overview in the Waypoints list is not enough.
                • As well as the routes information
                To be found on the left in the menu under the three lines or on the mobile phone below under Route details
                Reinhard-32
                Tom Balmerundefined
                Tom Balmer
                  Massimo Cardoneundefined
                  Massimo Cardone
                  6.2k
                • Veekeersinfo en omleiden
                  marko 11 0undefined
                  marko 11 0
                  38.7k
                  13.0k
                • Library sync error
                  undefined
