  4. GPS Problems with the rugged blackview bv6200 plus.
7 Posts 4 Posters 3.1k Views 2 Watching
  • Emanuele 5
    Emanuele 5
    Emanuele 5
    I have a friend who has this problem:
    using the myroute app navigation with Blackview bv6200 plus rugged smartphone He has problems with GPS.
    Navigating a route:He noticed that after a while the gps crashes,no longer updates the GPS location.
    It is forced to restart your smartphone and resume navigation.
    Do you have any experience on this?
    Thanks.
      You mean that his GPS chipset does not renew the location? That is a problem that would also show on other apps I presume. If it does, your friend will need to send it in for repair.
      Emanuele 5 1 Reply Last reply
      • RainerT
        RainerT
        RainerT
        I also used a Blackview for navigation with MRA for some time.
        If it's not a hardware defect, then the energy-saving options often cause problems and simply shut down running apps.
        Your friend will need an hour to work through all the options. This part is not specific to Android, but is often programmed separately by the manufacturer. And Blackview in particular is not very good at documentation.
        There is also a special forum in English hosted by the company. However, it is located in China, so please bear in mind that practically everything there may be read by others.
        RT
        BMcG Emanuele 5 2 Replies Last reply
        • RainerT RainerT
          RT
          wrote on last edited by BMcG
          @Emanuele-5 I'm using a rugged BV7100, no issues
          it does sound as @Con-Hennekens suggests, the GPS is maybe being disabled or a permssion for background use needs to be set to always
            Emanuele 5
            Emanuele 5
            Emanuele 5
            Thank you for your answer.
            The problem occurs not immediately, but after a while navigating a path with myroute app navigation,
            type after 1h navigation.
            He is testing to see if it also happens with other apps.
            • RainerT RainerT
              RT
              Emanuele 5
              Emanuele 5
              Emanuele 5
              @Rainer-Treichel
              Can you give me more precise references?
              Like a link where you can read the procedure to do?
              Thank you.
              • RainerT
                RainerT
                RainerT
                https://support.google.com/nexus/answer/3467281?hl=de
                https://support.google.com/nexus/answer/6179507?hl=de
                https://support.google.com/nexus/answer/3467281?hl=de&sjid=12928737613070150242-EU
                Emanuele 5
                Emanuele 5
                RainerT
                RainerT
                • eCharger and Range
                • Stopover expiration time notification
