  4. Scrolling Through Waypoints
25 Posts 6 Posters 13.8k Views 5 Watching
    You are planning a 15 day tour from your phone? That is some next level dedication.
    JP d
    JP d
    JP d
    wrote on last edited by JP d
    #21
    @Corjan-Meijerink yes, because the phone's processor is so fast and I don't have a laptop.
    But when I'm planning with my friend on his laptop it's really handy having the waypoints to the left all the time. Especially now I'm having the issue with scrolling through the waypoints. 🍻
      I can't reproduce your issue on my iPhone 13. I can smoothly scroll through all the waypoints. I used a route with 180 waypoints and scrolled through them the way you described. It works perfectly for me. Have you also tried using the in-app planner directly? So without first going to the website and opening the route there?
      Edit: On my S24 running Android, you do indeed have to be a bit more careful when scrolling! You're right about that. It does work, but pressing a bit too hard causes the app to open the waypoint you last touched while scrolling. Strange that I don’t have any issue with this at all on iOS.
      On the other hand, when I use the in-app planner, I can scroll as much and as wildly as I want—even on Android! Would using the in-app planner be something for you to consider?
      JP d
      JP d
      JP d
      @Rob-Verhoeff hi Rob, a bit late but finally got round to testing and recording trying to scroll through the waypoints list in the MRA app. As you can see I still have the same problem...
      Like I said previously I could scroll normally. I don't know what changed.
      I raised a ticket and they said they had no explanation to the glitch.
      https://youtube.com/shorts/Ea4a7BJ6s94?si=iqXKl07F8KwpeTd5
        I have two very different Android phones, and both do not show this problem I see in your video. But indeed, like @Rob-Verhoeff says, why not use the in-app planner?
        JP d
        JP d
        JP d
        @Con-Hennekens hello Con lad. Hope you've been well. 🍻
        I have the same problem with the app. Still can't Scroll. I don't know what changed but I'm guessing it's a bug due to something else being changed or adjusted.
        Brian McG 1 Reply Last reply
        • JP d JP d
          @JP-d I have seen / had this issue in the past & it is exceedingly frustrating when it occurs
          but it is not something I can repeat now, all seems to be working fine at present on a Oneplus 8 & Blackview BV7100
          no idea whats changed to stop it happening for me
          JP d 1 Reply Last reply
          • Brian McG Brian McG
            JP d
            JP d
            JP d
            @Brian-McG I wonder if it's an issue with Oneplus then... Thanks for letting me know you had an issue but then it stopped. Mine started with 4.4.0. Don't know what changed.
            JP d
            JP d
            • Live tracking
              eyal 0
              eyal 0
            • Routing issue
              Léon Hassing
              Léon Hassing
            • Bar Buttons problems
            • Automatische routeaanpassing bij werkzaamheden gaat vreemd.
            • Compare providers error
            • Overlapping routes
            • Search from AA Auto not working
              peha
              peha
