  2. Routes & Tracks
  3. Garmin XT2 waypoint
Garmin XT2 waypoint
5 Posts 4 Posters 2.2k Views 1 Watching
  • Paolo 10
    Paolo 10
    Paolo 10
    Hi, I tried to export all the Gpx 1 2 with the waypoints from myrouteapp to the Garmin Tread app, but it doesn't let me see the waypoints in Tread and on the Garmin XT2, can anyone help me. Thanks
    • Paolo 10 Paolo 10
      @Paolo-10 hi Paolo
      If you export with 1.2 only the vuapoints are vissible and is exactly what is supposed to be
      • Paolo 10 Paolo 10
        @Paolo-10, To add to Marinus: if you want all waypoints visible, use the GPX 1.1 instead. Be aware that you will need to set your avoid/allow and shortest/quickest options on your Zumo identical to ones you used while planning. You will be navigating a route (trip) not a track.
        • Paolo 10
          Paolo 10
          Paolo 10
          hello and thank you for your answers, I tried to export to Gpx1 and 2 the waypoints do not show them, until a few months ago I used the Mappite app on WEB, I was able to put the waypoints even rename them, and export them to Garnin XT2, it always worked fine. I thought that with myroute there was no problem. I also noticed exporting to Gpx1 or 2, and then importing it into Mappite, the waypoints do not show them to me. I think the problem is due to Myroute WEB, I'm sorry they can't solve the problem. They have nice graphics, a nice intuition on the programming of the routes.
          • Carl Lee
            Carl Lee
            Carl Lee
            wrote on last edited by Carl Lee
            GPX1.2 is a MRA invention designed to build a route from a track. Tread does not play nicely with it so use 1.1 instead which will show your waypoints, via points and shaping points.
            Carl Lee
            Carl Lee
            Paolo 10
            Paolo 10
