  3. Reverse your route?
Reverse your route?
3 Posts 2 Posters 827 Views 1 Watching
  • Matthew Perkins 0
    Matthew Perkins 0
    Matthew Perkins 0
    If you have created a route and you want to do the same route in reverse is there an easy way to do this ??? Am using MRA navigator also via Android auto in case the app has an option? or do i need to recreate the route as a separate route in reverse manually? Thanks in advance.
    • Matthew Perkins 0 Matthew Perkins 0
      @Matthew-Perkins-0 Hi Matthew
      If you have an MRA gold abo there's an option to reverse the route, option in the toolbox.
      So make a couple of the route. Reverse it AND check all the waypoints to make shure they're on the right side of the road
      Matthew Perkins 0 1 Reply Last reply
        Matthew Perkins 0
        Matthew Perkins 0
        Matthew Perkins 0
        @Marinus-van-Deudekom Many Thanks will give that a go!
        Matthew Perkins 0
        Matthew Perkins 0
        • Routenplaner on iPad
        • Rondrit generator ervaring
          Sam Kramer
          Sam Kramer
