  2. Routes & Tracks
  3. How to merge 2 roads
16 Posts 4 Posters 4.8k Views 2 Watching
  • Francois Many
    Francois Many
    Francois Many
    Hello,
    I am a new incomer.
    I am a biker on a BMW R1250 GSA
    I would like to know how to merge two road.
    Thank you for your help
    Francois
    • Francois Many Francois Many
      Hello,
      I am a new incomer.
      Francois
      @Francois-Many
      Search in the "support" menu for:
      Manual 'Display and merge multiple routes'
      Francois Many 1 Reply Last reply
      • Joe Hoss
        Joe Hoss
        Joe Hoss
        Francois, are you trying to merge two separate routes together or figure out to adust the route to use two roads?
        Joe
        Those who wander are not always lost....
        • Joe Hoss Joe Hoss
          Joe
          Francois Many
          Francois Many
          Francois Many
          @Joe-Adam hello, I try to merge two separate routes
          Joe Hoss 1 Reply Last reply
            Joe Hoss
            Joe Hoss
            Joe Hoss
            @Francois-Many
            Ok, then I believe Jack has given you the best advice.
            Cheers,
            Joe
            • TorqueRider TorqueRider
              @Francois-Many
              Francois Many
              Francois Many
              Francois Many
              @Jack-van-Tilburg Thank you for yours help, I will try to found in the support menu. All the quiery must be in english ?
              Joe Hoss TorqueRider 2 Replies Last reply
                Joe Hoss
                Joe Hoss
                Joe Hoss
                @Francois-Many Sorry, I am not sure, I only speak English and have the website set to English.
                What happens when you click help on the bottom left? Do the new screen show in your language of choice?
                Joe
                • Joe Hoss Joe Hoss
                  Joe
                  Francois Many
                  Francois Many
                  Francois Many
                  @Joe-Adam I am French and all the menu is in french. So when I try to find all information with "merge" the answer is : no matching....
                    @Francois-Many
                    Support menu is also in French; Soutien
                    But i don't know what query to use for: "merge multiple routes:
                    • Joe Hoss
                      Joe Hoss
                      Joe Hoss
                      @Jack-van-Tilburg said in How to merge 2 roads:
                      fusionner plusieurs itinéraires ??
                      Joe
                      Francois Many 2 Replies Last reply
                      • Joe Hoss Joe Hoss
                        Joe
                        Francois Many
                        Francois Many
                        Francois Many
                        @Joe-Adam I wrote "Fusionner 2 routes" but no answer. Do you know is there some french user in this community or I have to change the language in English ?
                        • Joe Hoss
                          Joe Hoss
                          Joe Hoss
                          Here is the direct link to that support page. So it should work in your language?
                          https://support.myrouteapp.com/support/solutions/articles/12000074673-manual-display-and-merge-multiple-routes-
                          Joe
                          • Joe Hoss Joe Hoss
                            Joe
                            Francois Many
                            Francois Many
                            Francois Many
                            @Joe-Adam I have change the language ans I have found Merge to routes. Thank you very much for your help. I will use the English language for now.
                            • Joe Hoss Joe Hoss
                              Joe
                              Francois Many
                              Francois Many
                              Francois Many
                              @Joe-Adam Thank you very much Joe for the link. As I said I have change the language and I have found your link with the English words. Thans
                              Francois
                                @Francois-Many
                                <Do you know is there some french user in this community>?
                                Maby you can use the Selve Service Forum. There is a French item.
                                • HABVEN aka MrMRA
                                  Hello Francois,
                                  Welcome on the MRA Forum.
                                  See this short video.
                                  With your input, this post could be even better đŸ’—
                                  Joe Hoss
                                  Joe Hoss
                                  Francois Many
                                  Francois Many
                                    Vincible
                                    Vincible
