  3. [App] Announcements
  4. New update! (4.3.7) - Track navigation improvements and CP / AA zooming
42 Posts 14 Posters 27.9k Views 6 Watching
  • Nick Carthew
    @M-Schrijver @Gaetano-9 What camera view are you using? Automatic zoom does not work with top down view. Adjust the camera view by tapping the compass.
    Gaetano 9 1 Reply Last reply
      What camera should i use?
      I do not think i use top down
      • M. Schrijver M. Schrijver
        @M-Schrijver North up and dynamic both have automatic zoom.
          Than it does not work in Android Auto.
          In the settings are 4 options:
          • Off
          • Speed related
          • Direction related
          • Both
          I use "Both" with dynamic zoom.
            • Off
            • Speed related
            • Direction related
            • Both
            @M-Schrijver Camera view has 3 options. Top down, north up and dynamic. You adjust the camera view by tapping the compass, it is not in the settings. Your camera view choice is stored and will be used next time until you change it.
            You see a notification each time you tap the compass that tell you which camera view is active and what zoom is available. My example shows top down is chosen and it is fixed zoom level.
              #26
              Yes, i know.
              The "compass" is set so dynamic.
              But in the settings are some settings which tells how the autozoom should behave. That one i've set to "Both"
                Yes, i know.
                @M-Schrijver Have you tried adjusting your default zoom correction? I have mine set to +0.0 which works for me.
                  #28
                  I did but i see very little changes. The global zoomlevel changes. But the range of zoom level does not change. The range of zoom level is very limited.
                  I don't have real figures about the zoom level. So i will use examples.
                  What it looks like to me at the moment
                  Maximum zoomed out (at 100 km/u) is 1 cm on screen is 200 meters in real. Maximium zoomed in (at slow driving or stop) is 1 cm on screen is 150 meter in real.
                  What I expect?
                  At 100 km/u. 1 cm on screen is 200 meters in real.
                  At 30 km/u/stop. 1 cm on screen is 30 meters in real.
                    Gaetano 9
                    Gaetano 9
                    Gaetano 9
                    @Nick-Carthew ....
                    Today I checked and used all the possible settings. The automatic zoom does not work on AA but on the cell phone yes. Even with Google maps. On a motorcycle the automatics are important, if it is not possible I will switch to a Tablet or a dedicated cell phone.
                    Léon Hassing 1 Reply Last reply
                    • Gaetano 9 Gaetano 9
                      @Nick-Carthew ....
                      Léon Hassing
                      Léon Hassing
                      Léon Hassing
                      I can confirm that the automatic zoom does not work in the new version on AA. With the same camera modus as I used in older versions and were it zoomed, it does not do now.
                      Also I experience that when I have used the new zoom buttons they remain on the screen. Because of this also the stop button overlays the maximum velocity sign.
                      LR 1 Reply Last reply
                      • Léon Hassing Léon Hassing
                        LR
                        LR
                        LR
                        wrote on last edited by LR
                        #31
                        Also bei mir funktioniert es jetzt endlich! Ich hatte bei den vorherigen Versionen das gleiche Problem.
                        Es ist aber ein bisschen tricki! Man braucht die richtigen Einstellung.
                        Den Standard Zoomfaktor in den Einstellungen habe ich auf -2. Zoomanpassungen auf Aktiviert.
                        Der Kompass steht auf Dynamisch.
                        Jetzt kommt es, mit der neuen Schaltfläche kann man zwischen manuellen und automatischen Zoomen umstellen. Wenn man die + und - Tasten sieht ist man im manuellen Modus! Hier wird nicht mehr auf die Kreuzung gezoomt.
                        Wenn man wieder die ganz unten rechte Taste drückt ist man wieder im automatischen Modus und es wird rein und raus gezoomt. Hat mich auch eine Weile fummeln gekostet!
                        @Admins
                        Bei der Version wird der Akku bei Android Auto extrem warm. Bitte unbedingt korrigieren!
                        Danke Lutz
                        • LR LR
                          @Admins
                          Danke Lutz
                          Léon Hassing
                          Léon Hassing
                          Léon Hassing
                          @LR Ich werde das Morgen mal versuchen. Danke.
                            Just to investigate.
                            As long as this screen is visible:
                            Automatic zooming will not work.
                            When zoom buttons are present, the top down mode is activated.
                            If you click the close button bottom right, the last used camera mode before entering the top down mode will be used again 🙂
                            When the buttons hide due to inactivity that does not mean the top-down mode is closed
                              Gaetano 9
                              Gaetano 9
                              Gaetano 9
                              @Corjan-Meijerink ... Ok... Does the auto zoom work for you at roundabouts or intersections? Because it doesn't work for me, in two different AAs. I think it's not difficult to understand your directions, at least I hope.
                              1. This is the setting on the mobile, the only one you can do and the other is the view on the AA to activate the automatic zoom... up to this point I hope I have succeeded.
                              Yesterday I navigated with AA in the car and today with Carpuride dedicated to the motorbike.
                              It works on the mobile phone but not on the two AAs.
                              If it works for you then there must be something that I can't activate, but all the adjustments on the map work, except the automatic zoom.
                              I am available for any viable solution. For goodness sake, I just need to use a unit of size when looking at the route without automatic zoom.. I sleep peacefully at night.. but if there is a function that simplifies, why not use it?
                              Thanks and sorry...
                              Google traslate...
                              • OGRIII
                                OGRIII
                                OGRIII
                                wrote on last edited by OGRIII
                                #35
                                When doing a simple A to B route two or three options are allowed. However whenever I choose a different route to drive it then reverts to the default route when driving off? How can this be prevented so that the route chosen is driven, not the default route? This is when I connect my mobile phone to the Android Auto screen.
                                  I can confirm the images of @Gaetano-9
                                  On my AA looks the same.
                                  • MartinW
                                    It looks like this is a new feature: When navigating a route that was not created with HERE, the navigation mode automatically switches to "route as track".
                                    This makes life a bit easier: I can leave the toggle "Navigate routes as tracks" turned off; routes created with HERE will be started in "route" navigation mode, others in "route as track".
                                    Clever concept; well done!
                                      This "feature" is already there for a while.
                                      MartinW 1 Reply Last reply
                                        wrote on last edited by MartinW
                                        #39
                                        @M-Schrijver said in New update! (4.3.7) - Track navigation improvements and CP / AA zooming:
                                        Really? Interesting. I did a lot of navigating "route as track", almost always with routes created with OSM, but I never recognized this automatic switch of navigation mode...
                                        • MartinW MartinW
                                          @Martin-Wilcke, I understand that you don't want certain map-details public. But you can choose to cut off unnecessary parts instead of blurring them 😉
                                          To be honest: me neither 😉
                                          But it seems very handy. If you disable "routes as tracks", HERE routes wile be navigated like always, and OSM/TT routes will automatically be navigated as tracks, which is the clever choice for those. 👍
                                          • 3
                                          JP d
                                          JP d
                                          Léon Hassing
                                          Léon Hassing
                                          OGRIII
                                          OGRIII
                                          Thomas Neumeyer
                                          Thomas Neumeyer
                                          Gaetano 9
                                          Gaetano 9
                                          Henk Oskam
                                          Henk Oskam
                                          LR
                                          LR
                                          CHRISTOPHER TOOP
                                          CHRISTOPHER TOOP
                                            Nick Elsom 0
                                            Nick Elsom 0
                                          • 0 van 15 klaar
                                            Mark Vroomen
                                            Mark Vroomen
                                            Bart van de Griendt
                                            Bart van de Griendt
                                          • Routelijn transparantie
                                            Mark Vroomen
                                            Mark Vroomen
                                          • AI Planner: missing number of planned days in Library
