  3. [Web] Announcements
  4. Further route overview improvements!
Scheduled Pinned Locked Moved [Web] Announcements
15 Posts 9 Posters 9.0k Views 4 Watching
    After the big success of the update from yesterday, we immediately implemented the most hear feedback 😏
    You can now immediately show all your content from that folder 💥
    One click to show them all.
    It has been limited to 20 routes / tracks per go to keep things working smoothly. Data from child folders is not included 🙂
    Hubert Thoring Bouke Ent 2 Replies Last reply
      @Corjan-Meijerink : Danke dafür, geht sehr sehr gut !!
      Geht super schnell und einfach, bin so sehr begeistert 🤩
      iPad 9. G iOS 27.2.1/iPhone 16e iOS 27.2.1/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
        Great function, well done Corjan. 👍
        • paul69
          hi @Corjan-Meijerink
          excellent update
          please see my other post reference free beer ✌️
          K1600 GTL
          iPhone 13 Pro, carpuride 702b
          • paul69
            i have had a play with this, i have routes grouped in folders which is the basis of the update.
            i click a route within a folder, day 1 to ferry
            i thenclick on add routes in left pane and given this
            i then click the relevant folder in this case Ireland 2025 which then gives this
            i then click add all, if you notice the routes are not in order, i know this is not an huge issue as they are all shown, but i am just pointing this out
            just to be clear this is not a complaint, i think this new feature is brilliant thanks to y'all
            K1600 GTL
            • No6671
              No6671
              No6671
              One further suggestion:
              The limit seems actually to be set at 20. -- Since many of us have already much more routes, it would be nice to screw up this limit.
              I would use this - long-awaited - function to show all the routes that have already been travelled. As an overview, so to speak.
              Great work! Thanks.
              Goran
              Get up. Travel. Make friends. Sleep. Repeat.
                The limit has been added for performance reasons.
                Loading unlimited routes in one go can lead to results you aren't happy with.
                I then am not happy to ensure you can load everything at once 🙂
                Regardless! 20 at a time it is, if you want to load 100 routes, it's just 5 clicks rather than many more before the update 😉
                Hubert Thoring 2 Replies Last reply
                  @Corjan-Meijerink : Eine Frage die bei der Planung von Routen und der schon erfolgten Ablage in einer Gruppe aufgetreten ist.
                  Würde das Anzeigen der Routen auch in der Ablage einer Gruppe funktionieren ?
                  Ich sehe links keine Möglichkeit nachdem ich Routen ausgewählt habe ...
                    Fixed 🙂
                    Not as you’d expect I guess but it is correct
                      Fixed 🙂
                      @Corjan-Meijerink : sauber und es geht was geht …
                      Danke, ☺️
                      • Richard 18
                        Richard 18
                        Richard 18
                        This is a good improvement, over loading routes individually. Thank you for making the effort to create the update.
                        As with the post above, it would be great if the list of the routes displayed on the left could be sorted and displayed alphabetically or numerically. I am sure that I and others create bundles of routes for each tour, numbering them by day: 01… 02…. 03…. etc etc Having them listed in order would be excellent.
                        Kind regards,
                        Richard
                        PS I have no problem with the 20 route limitation.
                        • Richard 18 Richard 18
                          Kind regards,
                          Richard
                          @Richard-18 : Yes 👍 also another good idea
                          • Don Stauffer
                            Don Stauffer
                            Don Stauffer
                            Very nice improvement, this makes the early stages of route planning easier.
                            Thanks to the programming team!
                              @Corjan-Meijerink compliment voor deze toevoeging. Mooi gedaan.
                                @Corjan-Meijerink :
                                Good morning Corjan,
                                Today there was a small appearance, with the beautiful colorful route overview.
                                Process: Slovenia/ Italy/ Austria
                                • Overview Around the location Nassfeldpass with all routes viewed!
                                • Image with map pushed down to see more, s. Fagenkreutz
                                Routes on the maps were erased horizontally... s. Picture. 🤔
                                Crashing the app:
                                After calling the route again in the route laboratory, it was okay again. 👍
                                That's right 👍
                                • Nick Carthew Nick Carthew referenced this topic on
                                Don Stauffer
                                Don Stauffer
                                Richard 18
                                Richard 18
                                No6671
                                No6671
                                  Jack 13
                                  Jack 13
                                • No skip waypoint on an A to B route
                                • Navigatie met DMD tablet
                                  Arjan de Vries
                                  Arjan de Vries
                                • Myrouteappstay
                                • Map met routes Offlne zetten lijkt het niet te doen
                                  Marcel Versluis
                                  Marcel Versluis
