  4. adding route to an event and back
8 Posts 4 Posters 2.2k Views 3 Watching
  • cvlmtg
    cvlmtg
    cvlmtg
    wrote on last edited by cvlmtg
    As far as I've understood, when I add a route to an event from my routes collection, the route is copied, not linked, so if I need to make changes I have to change the route in the event. What I haven't found (searching in the manuals and the forums) if it's possible to copy this route back to my routes collection...
    edit: nope, I just found out that I cannot edit the route in the event 🤔 how it is supposed to work on an event route? can I just add routes without any chance to modify them?
    Thanks in advance!
    • cvlmtg cvlmtg
      Thanks in advance!
      @cvlmtg
      Delete the route from the event
      Adjust the route in your library
      Add the route to the event (a new copy is made)
      cvlmtg BMcG 2 Replies Last reply
        @cvlmtg
        cvlmtg
        cvlmtg
        cvlmtg
        @Hans-van-de-Ven-MR-MRA ok, thanks!
          @cvlmtg
          Hi @Hans-van-de-Ven-MR-MRA
          I understand that the delete, adjust, re-add is the way it works, I think this also applies to Groups as well.
          Could youn you explain why this is necessay & why the routes in Events & Groups can not be dynamically linked to the creators own route library?
          I understand that a dynamic link feature would not be a priority just curious if there is a reason why it is like it is & if it may change in the future
          As things currently work, I dont see much use for Events or Groups but instead just create a folder in my own library & share this with firends or public.
          MotoCon HABVEN aka MrMRA 2 Replies Last reply
          • BMcG BMcG
            @Brian-McG, This allows the source route to be altered for different purposes or events, without the current event being compromised.
            BMcG 1 Reply Last reply
              @Con-Hennekens in that scenario where I wanted to modify a route in my library but keep it the same in the event or group,
              would it not be easier just to create a new copy of the route in my library?
              that would be one simple click rather than the rigmarole of delete, adjust, add
              • BMcG BMcG
                @Brian-McG
                This was decided when building the application, so that routes that are placed in an event or group are a copy of the original that is in your library. And that the original route always remains the original route until you adjust it. And that is only possible in your own library.
                • BMcG BMcG
                  @Brian-McG said in adding route to an event and back:
                  To be honest, I think not 😉
                  In your route library there is no clear indication of your route being part of an event. So an error is made easy.
                  cvlmtg
                  cvlmtg
                    Rory Burke
                    Rory Burke
