  3. [Beta] Announcements
  4. Updated beta v4.2.0 (320)
12 Posts 8 Posters 264 Views 5 Watching
    Hi all!
    In preparation for the release, the final beta update is coming your way 🎉 We made some adjustments to the planner, improved some minor stability things and processed your feedback.
    We are aiming to release it to the public next week! 😃
    Cheers,
    Corjan
    Hubert Thoring Marinus van Deudekom Rob Verhoeff 4 Replies Last reply
      Hi all!
      Cheers,
      Corjan
      @Corjan-Meijerink : That will be gladly heard, thank you for that!
        Hi all!
        Cheers,
        Corjan
        This post is deleted!
          Hi all!
          Cheers,
          Corjan
          @Corjan-Meijerink The320 is available for Android
          Stanisław 1 Reply Last reply
            @Marinus-van-Deudekom Also for IOS it is accessible in TestFlight.
            Regards
            Staszek
            • Dave J 0
              @Corjan-Meijerink A couple of possible issues when using Car Play:
              • Camera Mode does not remain at last setting mode in Car Play. I can set to 3D but in the next startup, it is back at 2D.
              • Adding stops. I do not receive the pop up of ‘Do you want to add….’ on Car Play when adding stops so that the stop addition times out. On my iPhone, the prompt is there and allows selection to add the point.
              Good work. Love the planner; use this a lot now.
              Ducati Multistrada V4 Rally
              iPhone 15 Pro
              CHIGEE AIO-6 LTE
                Hi all!
                Cheers,
                Corjan
                @Corjan-Meijerink Planned a route from just below Frankfurt towards the west of the Netherlands with the new planner. Everything worked seamlessly, including planning, navigation, voice instructions, and recording the tracklog. After pausing, the route resumed perfectly. CarPlay also had no issues. Corjan, thank you for this wonderful update.
                • RetiredWingMan
                  I noticed today that if you start a A to B route, the track log is not automatically started. Is this correct or based on the option should the tracking have started automatically?
                    @RetiredWingMan A tracklog only starts automatically when navigating a route (if the toggle is on in the settings).
                      @Rob-Verhoeff @RetiredWingMan indeed never for A-B 🙂
                      • Dave J 0 Dave J 0
                        @Dave-J-0 thanks! We will check that 🙂
                          @Corjan-Meijerink : There would still be something to adjust before the published... at least from my point of view something that could be even better so that the user learns to love it before he does it badly.
                          Test der neuen v4.2.0 (320)
                          Small things, but they should also go clean without compromise.
                            2.3k
                            2.2k
                          • Seizoensafsluitingen
                          • Altitude numbers size
                            RainerT
                            RainerT
