How to add library routes to a route i am currently planning
Hi. i am currently planning a European tour. I have been looking at the library routes and would like to incorporate some of these into the route I am planning.
Is it possible to 'import' a library route to use as part of the route i am planning for that day.thanks
Hi @Tattz,
The short answer is "Yes"
The longer answer :-
If you click on a route in the Library in the web planner this will open a page showing an overview of the route.
Bottom right of the overview map you should see a box with the name of the route & some details like distance & author, click on the name of the route.
This will open the route in the route web planner, from the (page) menus you then want to select "Use Route" to transfer/import the route into your personal list of routes from where you can edit the route as normal.
If you want to stitch this route together with other routes you will can follow the instruction from the manual 'Display and merge multiple routes' -
@Tattz, another method is to pick the route using the "use this route" function to copy it into your own library. Add a route point and move it to the start (or use the "start from here" function in the waypoint menu). Add extra waypoint by clicking ON the route line and move them to desired locations.
