  4. MRA Connection do not find my Garmin XT2
8 Posts 3 Posters 2.7k Views 3 Watching
  • TomOnTour
    TomOnTour
    TomOnTour
    Dear all!
    I am using an Apple macPro Air with Safari ad Chrome as the used browser for MyRoute-app and downloaded as documented the MacOS MyRoute-app Connector. If I now connect my Garmin XT2 via an original Garmin USB cable, the Connector does not find my connected XT2.
    I did't expect that, so I thought it might be an issue with the the Mac and the XT2, so I started Basecamp to check if my XT2 will be found by Basecamp. This works totally fine.
    So, now my question is, why the mMyRoute-app connector do not find my XT2?
    Meanwhile I extended my tests:
    I installed Garmin Express which also finds the XT2.
    I used a Windows Laptop and connected my XT2 to the PC and used the MyRoute-app Connector and this also worked perfect.
    So it looks like a problem with a) the MacOS version of the Connector. Any ideas?
    Greetings
    Tom
    MacOS Verson is: 14.4.1
    XT2 with actual Firmware
    Safari Version 17.4.1
    • TomOnTour TomOnTour
      Dear all!
      Greetings
      Tom
      @TomOnTour
      That is right, see: https://forum.myrouteapp.com/topic/1396/garmin-zumo-xt-mac?_=1715922923937
      TomOnTour 1 Reply Last reply
        @TomOnTour
        TomOnTour
        TomOnTour
        TomOnTour
        @Hans-van-de-Ven-MR-MRA said in MRA Connection do not find my Garmin XT2:
        @TomOnTour
        Hi Hans!
        Thx for the link. I have read it before, but forgot about it 🙂
        Really annoying what Argon is doing there. It is just another little bit of complexity nobody really needs.
        I will play around with this a bit and see how it really feels in the day to days use.
        It more an more looks like, that my XT2 will leave me sooner then later and will move to MyRoute-app Next only 🙂
        Greetings
        Tom
          @TomOnTour
          Hi Hans!
          Greetings
          Tom
          @TomOnTour
          Save route as... and transfer it via Android File Transfer to the GPX folder on the XT2 or send the route to the Tread app via the MRA app, then use gpx 1.1 because the Tread app / Garmin Explore does not handle the gpx properly 1.2.
          The designers may be able to adjust the connector in such a way that in the future it will be possible to transfer the routes to the XT(2) in combination with a Mac.
            @TomOnTour
            TomOnTour
            TomOnTour
            TomOnTour
            Does the GPX 1.2 also includes the all Shaping points correctly?
            Greetings
            Tom
            Hubert Thoring HABVEN aka MrMRA 2 Replies Last reply
              Greetings
              Tom
              @TomOnTour : Hallo,
              wenn Du ein iPhone nutzt solltest Du das mal testen, unterwegs hat man das Handy ja auch immer dabei und kommt über die MyRouteApp an alle Routen um diese an das XT oder XT2 zu übertragen.
              App Austausch
              • App für XT „Garmin Drive“ geht sehr gut
              • App für XT2 „ ? „ vielleicht auch „Garmin Drive“
              Kabel Übertragung
              • so gehts mit dem N6 s. Bild
              • USB Adapter von Appel „original verwenden“
              • geht vielleicht dann auch mit dem XT oder XT2
              Bild mit N6 (BMW Navigator VI)
              @TomOnTour: Hello,
              if you use an iPhone you should try it out, you always have your phone with you when you're out and about and you can access all routes via the MyRouteApp and transfer them to the XT or XT2.
              App exchange
              • App for XT "Garmin Drive" works very well
              • App for XT2 " ? " maybe also "Garmin Drive"
              Cable transfer
              • this is how it works with the N6, see picture
              • USB adapter from Apple "use original"
              • maybe it will work with the XT or XT2
              Picture with N6 (BMW Navigator VI)
              iPad 9. G iOS 27.2.1/iPhone 16e iOS 27.2.1/ iPhone Xr iOS 18.7.11 / PC Win11 /❗️MRA & BMW Cradel & Remotek One ❗️.. & ..❗️Navi Halter3D Druck Senkrecht ❗️
                Greetings
                Tom
                @TomOnTour said in MRA Connection do not find my Garmin XT2:
                gpx 1.2 is a route-track with via points, the gpx 1.1 includes alle shaping and via points. If you want to use the Tread app use the gpx 1.1
                See also: https://info.myrouteapp.com/blog-routes-loading-garmin-zumo-xt/
                  @TomOnTour : Hallo,
                  App Austausch
                  Kabel Übertragung
                  @TomOnTour: Hello,
                  App exchange
                  Cable transfer
                  @Hubert-Thoring said in MRA Connection do not find my Garmin XT2:
                  Nein, Garmin hat die Tread-App für den XT2 gestartet, die direkt mit der Garmin Explore-Website verknüpft ist.
                  TomOnTour
                  TomOnTour
                  • Real-time traffic
                    Andy Nicholson
                    Andy Nicholson
                  • HERE map not calibrated
                  • Myrouteappstay
                  • Navigatie met DMD tablet
                  • Show on the maps's button
