  4. Add option for stripping shaping points in gpx export
30 Posts 9 Posters 14.6k Views 3 Watching
    Just an idea, compare the files in an text editor to see what is different.
    martin-phogel.de Offline
    martin-phogel.de
    @Jörgen
    Yes, that was exactly my idea. I use MS Visual Studio Code, which has a good compare feature.
    There are a few differences between the MRA and the BC version and I'm trying to figure out which one is crucial. Unfortunately, the gpxx extensions are probably responsible for that, but they are a proprietary Garmin development and not publicly known. Most of the time you can only get to the bottom of these effects by trial and error...
      @ConiKost
      The developers should dive into that as soon as they have time
      martin-phogel.de
      @Hans-van-de-Ven-MR-MRA said in Add option for stripping shaping points in gpx export:
      Of course! But perhaps we can try out a few things in advance to make it easier for the developer to analyse the problem.
      This topic is a broad field and you can invest quite a lot of time in it.
        Astonishing.
        Perhaps it is not due to a lack of information about the waypoints but to the definition of the route itself.
        Would you like to investigate this issue further?
        If so: I have changed the route again, it is now Version 3.
        https://hidrive.ionos.com/share/pquvtok.yw
        Can you please download it to your device?
        If there are still no ViaPoints displayed, it would be interesting to know whether they are actually there and are just not shown or whether they have been removed.
        Do you have the option on the device to
        a) load the route and display the waypoints before starting the navigation? This should then look something like this:
        b) start the navigation and then display the directions? Something like this:
        I'm curious to see if we can track down the problem 🙂
        ConiKost Offline
        ConiKost Offline
        ConiKost
        wrote on last edited by ConiKost
        #23
        @Martin-Wilcke Thank you for your help. I am interested in further testing 🙂 Your number 3 test works, that all VIA points are now being shown. But the whole route is gone. The route is now point to point shown.
        Unfortunately, the Montana route planer does not show the VIA points in a list as your Zumo does. This is a sutpid Garmin software decision, as the GPSMap 276Cx could do this and was based on Montana software.. the only option, where is does show VIA points like Zumo in a list, if I do transfer a route from Basecamp with "Direct Navigation". Thats the only case, where this works. You can find such example route here: clickme (This means only straight lines, no routing)
        This is can example, what I mean. It only works with my uploaded direct Route from Basecamp. Your "MRA Route Version 3", despide being direct, does not show its points, so it's apprently not detected as direct route?
        @Hans-van-de-Ven-MR-MRA Great, many thanks. Do you want to open for that a support ticket?
        Shiny!
        • martin-phogel.de Offline
          martin-phogel.de
          @Peter-Schiefer
          Thanks for the link, I‘ll check it out!
            martin-phogel.de
            @ConiKost
            OK - here comes the next and hopefully final attempt (Version 4):
            This version contains all the additional information from the BC file, which either has static values or can be derived relatively easily.
            I'm curious to see if it works!
              martin-phogel.de
              @ConiKost
              ooops, little bug in version 4, please use version 5.
              ConiKost 1 Reply Last reply
                @ConiKost
                ConiKost Offline
                ConiKost Offline
                ConiKost
                @Peter-Schiefer Thanks, I will have a look.
                @Martin-Wilcke Thank you. I tried V5 and Unfortunately no change. Still missing VIA points.
                Shiny!
                martin-phogel.de Canario 2 Replies Last reply
                • ConiKost ConiKost
                  martin-phogel.de
                  @ConiKost
                  Too bad. Then the gpxx:subclasses must probably also be included, but I have no idea how the content can be determined or derived. Maybe someone else has an idea...
                  • ConiKost ConiKost
                    Canario Offline
                    Canario Offline
                    Canario
                    @ConiKost
                    I use outdoor Garmins since decades for my Moto bike Tours. Having ViaPoints part of the route is one of the most important things for my routing. With export/import of the GPX 1.2 files and recalculation set to off in the Montana 700i, the Routing works fine but the ViaPoints are missing.
                    It surely seems to have something to do with the GPXX : Subclass Tags. It would be great, if ViaPoint support for Garmin Outdoor Devices could be implemented in MRA. Until then, I will stick with Basecamp, possibly running on a virtual machine with Windows 10 or 11 in the future.
                    • Canario Canario
                      @ConiKost
                      ConiKost Offline
                      ConiKost Offline
                      ConiKost
                      @Canario said in Add option for stripping shaping points in gpx export:
                      @ConiKost
                      To be honest, I don't have high hopes, that this will be proper supported in future, as most of the users here uses automotive devices like Zumo/Tread. And the roadmap seems to have more important features on it's list (which I can even understand..)
                      Shiny!
                      ConiKost
                      ConiKost
                      martin-phogel.de
                      martin-phogel.de
                      GT JWR
                      GT JWR
                      Erdna
                      Erdna
                      Canario
                      Canario
                        g.bolijn 1 0
                        g.bolijn 1 0
                      • Google maps and Streetview
