  4. Passo Predil
Passo Predil
4 Posts 3 Posters 1.0k Views 2 Watching
  • Franz B. 1
    Franz B. 1
    Franz B. 1
    Why isn’t it possible to create a route with the here map over the Passo Predil (between Slovinia and Italy)? It is possible with the TomTom or OSM maps, but with Here and the Navigator is using this map.
    Marc Wittevrongel Stefan Hummelink 2 Replies Last reply
    • Franz B. 1 Franz B. 1
      Marc Wittevrongel
      Marc Wittevrongel
      Marc Wittevrongel
      @Franz-B-1 Sometimes it is caused by roads that are temporary closed. Some Alpine passes are closed during winter...
      Not sure of course if that is the case for you.
        @Franz-B-1 try disabling the seasonal closures from the here toolkit menu and see if that helps!
        Franz B. 1 1 Reply Last reply
          Franz B. 1
          Franz B. 1
          Franz B. 1
          @Stefan-Hummelink, thank you for your hint. This pass does normally not have a seasonal closure, but I deactivated it in the routing tools and it worked. I didn’t even think about that, because it is a shallow pass, but again, thank you.
          Franz B. 1
          Franz B. 1
          Marc Wittevrongel
          Marc Wittevrongel
            4.2k
          • Points of interest
            Lluís Casals
            Lluís Casals
            4.2k
          • Altitude numbers size
            JP d
            JP d
