  4. Map Zoom uncontrolled
6 Posts 3 Posters 1.7k Views 2 Watching
  • rh.norrisyahoo.co.uk
    When I use the mouse wheel to zoom on the map the zoom does multiple zooms for one click of the wheel (and yes I have changed my mouse settings).
    I tried several Mouse configurations and even went as far as buying a model that someone said worked OK in a thread last year. But no joy.
    However, I asked a colleague if I could use his mouse (Microsoft) and it worked and then I found a wired rather than wireless mouse and that worked too. So why doesn't MRA like Logitech wireless mouse ?
    I'd really like to know what the problem is with some wireless mouse configurations, or if someone has a fix rather than a workaround.
    • rh.norrisyahoo.co.uk rh.norrisyahoo.co.uk
      @rh-norris no clue 😞 Must really be something with that mouse.
        @rh-norris, Why make a second post about this. I am not going to maintain multiple threads about it.
        https://forum.myrouteapp.com/post/39741
        @Corjan-Meijerink, maybe better lock this one?
        rh.norrisyahoo.co.uk 1 Reply Last reply
          @Con-Hennekens The system made an automated suggestion that as the original question was quite old it would be better if I started a new thread. So I did. If you don't like this then maybe the system needs to be changed.
            @rh-norris, It is perfectly fine to start a new thread, but it is less fine to re-activate the old one. Or to do both actually 😉
              @Con-Hennekens: Noted - thank you.
              • Real-time traffic
                Andy Nicholson
                Andy Nicholson
              • HERE map not calibrated
              • Myrouteappstay
              • Navigatie met DMD tablet
              • Show on the maps's button
