  3. Garmin ZUMO XT2 Import Waypoints
5 Posts 3 Posters 2.3k Views 2 Watching
  • Mat Jones
    Mat Jones
    Mat Jones
    Sorry if this is in the wrong area, I have created a route I want to take from from start to finish with 15 way points.
    When I export this route “GPX 1.1” and import this into Garmin Tread I then go onto my ZUMO and open the route.
    I can not for the life of me get the map to show all the way points and then to hit start and it direct me to next waypoint instead it just maps a route using the way points it asked me where I want to go to next, there is no option to go to the next labeled waypoint.
    Thank you in advance
    Taff
    • Mat Jones Mat Jones
      Taff
      @Mat-Jones
      Please share the url of the route here. Make sure it is set to public
      Mat Jones 1 Reply Last reply
        @Mat-Jones
        Mat Jones
        Mat Jones
        Mat Jones
        @Hans-van-de-Ven-MRA-Master https://www.myrouteapp.com/route/open/8622355
          @Mat-Jones
          A route of 427 KM with only 13 shaping points is asking for problems. Depending on the environment, we maintain a shaping or via point every 4 to 5 KM.
          Also make sure that the points are positioned correctly on the route line, to avoid surprises.
          If your route is technically well constructed, it will be processed well by your XT2.
          Please note that if you use the Tread app, you use the GPX 1.1, but it is best to set the route via the connector or save as on your XT2. Reason: the Tread app is essentially the Garmin Explore website and Garmin Explore does not handle routes well, but it does handle tracks
          • nomko
            Banned
            Normally i place a tracking point/waypoint after each turn i have to make (left/right turn) at intersections or junctions. Thus will create a route with a lot of waypopints/tracking point, but you won't go wrong with the route itself since you "force" MRA to plot the route you crerates like that.
            Mat Jones
            Mat Jones
            • Live payments enabled
            • Maps Michelin
            • Pay for beta?
              Brett Bartick
              Brett Bartick
            • MRA head up display BMW auto
            • Waypoints are not displayed in CarPlay/Android Auto.
            • import in beta-mra failed
