  3. [App] Announcements
  4. New update! (4.0.8)
New update! (4.0.8)
57 Posts 16 Posters 38.7k Views 7 Watching
    @Hans-Lamers how do you get 30 or 48W from a 3 amp 5v charger? W=V*A
    Edwin_M Offline
    Edwin_M Offline
    Edwin_M
    @Doug-Robinson 12 volt cigarette lighter
    • Dikke Wim Dikke Wim
      @Hans-Lamers
      Is Keyvovo Official Store een onderdeel van Alibaba?
      Ik kan de 48W oplader niet vinden.
      Heb je een linkje?
      Hans Lamers Offline
      Hans Lamers Offline
      @Dikke-Wim Inderdaad Aliexpress
        Hans Lamers Offline
        Hans Lamers Offline
        wrote on last edited by Hans Lamers
        #23
        @Doug-Robinson Ik heb geen idee, ik kijk naar de beschrijving (zie de afbeelding). Wat ik heb ervaren is dat deze auto opladers bij mij prima werken👍
        Of zou het gerekend zijn op de 12V x 4A ??
        • Hans Lamers Hans Lamers
          RetiredWingMan Offline
          @Hans-Lamers misleading. As far as the phone is concerned, the output of the charger/adaptor is 5V at a max of 3 amps = 15 w. I hope my recently purchased Quadlock wireless charger does better than yours. I purchased the 15w version that needs to be direct wired to a 12v source rather than plugging into a USB port. I have also found that the quality of the USB cable can seriously affect charging rates. Keep cables as short as possible.
          Edwin_M Dikke Wim 2 Replies Last reply
            Edwin_M Offline
            Edwin_M Offline
            Edwin_M
            @Doug-Robinson I bought the same setup for that reason too. I was always doubtful using it with my s21fe. The battery usage issues with the app blurred my sight on it a bit.
            I was hoping that the s24+ with better processor screen etc would perform better
            But now it seems to be an issue with the quadlock wireless charging head.
            Maybe we should create a separate forum topic on the subject.
              Dikke Wim Offline
              Dikke Wim Offline
              Dikke Wim
              #26
              @Doug-Robinson
              My Quadlock wireless charger also cannot keep up with the drainage of battery while using MRA. I'm using an iPhone 13 Pro Max.
              Thanks for the tip to look into the charging cable!
                @Doug-Robinson
                Hubert Thoring Offline
                @Dikke-Wim :
                I use an iPhone Xr in the BMW cradle, which fits well. I haven't had any battery problems so far and everything was great for the whole day, even on a longer tour.
                There were several apps open...
                Ich nutze ein iPhone Xr im BMW Cradel, das passt gut. Ich hatte bis jetzt keine Akku Probleme und auch bei einer längeren Toure für den ganzen Tag alles Top.
                Es waren mehre Apps geöffnet, …
                iPad 9. Gen iOS 26.6.2/ iPhone 16e iOS 26.6.2/ Navi iPhone Xr iOS 18.7.10 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
                  @Dikke-Wim :
                  @Hubert-Thoring
                  I think the BMW cradle supplies more power than the Quadlock or SP connect.
                  Edwin_M 1 Reply Last reply
                    @Hubert-Thoring
                    Edwin_M Offline
                    Edwin_M Offline
                    Edwin_M
                    #29
                    I did some additional testing and I must say that I am dissapointed in the performance of the Quadlock Wireless Charger (with USB connection). It is a very expensive accessory and it is advertised to reach up to 10W with Galaxy devices. (using a good power supply ofcourse).
                    And yes the power drain of the MRA next app is still on the high side.
                    In short , the wireless charger does not exceed 6W of power supply in my tests.
                    Phone is an S24+ .
                    Case is a Quadlock Mag Case
                    I have the USB connection version of the Wireless charging head. combined with the Motorcycle - Waterproof 12V To USB Smart Adaptor - Quad Lock® Europe - Official Store (quadlockcase.eu)
                    I did some testing:
                    1. Checked on phone: Turned of battery protection and checked all battery fast charging options are on. Used an additional quality USB-A to USB-C cable to test (otherwise I'll need to get a lot of covers of of my motorcycle) all fast charge options are enabled
                    2. Without Quadlock: tested directly on the a charger : outcomes: On an USB-A output max 2,4A => 7 W charging second USB-A output with a QC3.0 => 12,5 W.
                      3, Quadlock hardware test: used the same cable wired directly on the 12V Quadlock convertor => 12 W
                    3. Quadlock hardware test: used the same cable from the 12V quadlock convertor to the wireless head = 6W
                    4. Quadlock wireless charging head connected to wall charger (as in bullet 2): 1. on QC3.0 port => 6W max via charging head second on normal port max 2,4A resulting in 3,4W max via charging head
                    response of Quadlock on results:
                    *Our wireless charging head has advertising on our product page to charge at a maximum of 10W, as yours is charging at 5W it still sitting with the expected performance.
                    Just to note that you will always have a faster charging speed using a cable as this is not surprising because we can't expect the wireless charge to perform the same.*
                    The latter is obvious. But losing 6W over the wireless charging head is dissapointing to say the least.
                    (i found that , with a 100 km roundtour, first edit in Routeplanner online) using it as a route from that to navigate with and using Dark mode, the phone was able to charge. In light mode , the drain is too big at the moment.
                    Also must state that I am always using Flitsmeister AND youtube music in background as well;
                    • Flat Twin Therapy Offline
                      Flat Twin Therapy
                      While it might be true or not that Quadlock does not charge as advertised, it still does charge my phone when navigating using another app like Waze and Google Maps, and MRA is draining the battery.
                      Also, the charger in my car (USB outlet in dashboard / not quadlock) does charge the battery when navigating with other apps, while the battery drains when using MRA.
                      (Android)
                      Since January 2024 I started recording some of my rides commuting and touring the R1200RT in The Netherlands:
                      https://youtube.com/@FlatTwinTherapy
                      • Flat Twin Therapy Flat Twin Therapy
                        (Android)
                        Edwin_M Offline
                        Edwin_M Offline
                        Edwin_M
                        @Flat-Twin-Therapy agree
                        • richtea999 Offline
                          richtea999 Offline
                          #32
                          @Edwin_M said in New update! (4.0.8):
                          ...I found that ... using it as a route from that to navigate with and using Dark mode, the phone was able to charge. In light mode , the drain is too big at the moment.
                          Not to allow HERE off the hook, but Dark mode is a good work-around until they pull their finger out and fix the problem for MRA.
                          It works for me, and will decrease battery usage on any phone with an OLED / AMOLED display, because they require power to light each pixel (rather than having a screen-wide backlight).
                          • Edwin_M Edwin_M
                            Phone is an S24+ .
                            I did some testing:
                            @Edwin_M what app are you using to measure/monitor the charging power?
                              Edwin_M Offline
                              Edwin_M Offline
                              Edwin_M
                              @Doug-Robinson accubattery
                                (Android)
                                Dikke Wim Offline
                                Dikke Wim Offline
                                Dikke Wim
                                #35
                                @Flat-Twin-Therapy
                                Besides the fact that the Quadlock wireless charges is not "strong" enough, some smartphones may stop charging because of a tempertaure that becomes too high as a result of all the calculations MyRoute has to do. See below:
                                • Jörgen Offline
                                  Jörgen Offline
                                  #36
                                  Just for information, with my Oukitel outdoor tablet I noticed that changing the USB charging cable it fixed the battery loading problem. The first cable did not supply enough power. First, I thought the 12/5V converter was the issue, but it was the cable.
                                  Anyway, has someone tried to see if Here's own navigation app has the same issue with power consumption?
                                    Edwin_M Offline
                                    Edwin_M Offline
                                    Edwin_M
                                    @Jörgen https://forum.myrouteapp.com/post/33259
                                      @Flat-Twin-Therapy no offence taken!
                                      It bothers me probably the most as not only user but also as person responsible for the technical stability / usability of the app.
                                      I have a meeting with HERE development next week in which they will update me on their progress 🙂
                                      Edwin_M Offline
                                      Edwin_M Offline
                                      Edwin_M
                                      @Corjan-Meijerink any Update/progress from the meeting with HERE?
                                      • Ton Verkleij Offline
                                        Ton Verkleij
                                        Hello,
                                        I would like to see the operation of the app completely independant from the smartphone, making it a real standalone app on Android whereas using it on Android auto I do not have to use smartphone at all.
                                        richtea999 1 Reply Last reply
                                        • Ton Verkleij Ton Verkleij
                                          Hello,
                                          richtea999 Offline
                                          richtea999 Offline
                                          #40
                                          @Ton-Verkleij said in New update! (4.0.8):
                                          Hello,
                                          I'm pretty sure Android Auto needs a smartphone to work. How were you hoping to install the app? (unless your vehicle's head unit is really a smartphone/tablet in disguise)
                                          Ton Verkleij 1 Reply Last reply
                                          • 3
                                          Edwin_M
                                          Edwin_M
                                          Dae 0
                                          Dae 0
                                          Dikke Wim
                                          Dikke Wim
                                          Lynchy67
                                          Lynchy67
                                          Ton Verkleij
                                          Ton Verkleij
                                          Flat Twin Therapy
                                          Flat Twin Therapy
                                          • Welke instelling
                                            1.1k
                                            Thomas Schäfer
                                            Thomas Schäfer
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • Seizoen sluitingen wegen
                                            PAT62
                                            PAT62
                                          • App loopt vast
                                          • Rejoining routes
                                            Sytze van der Laan
                                            Sytze van der Laan
