  4. Streckenführung über das Meer
14 Posts 5 Posters 4.2k Views 1 Watching
  • Wolfgang Horn
    Wolfgang Horn
    Wolfgang Horn
    Hallo,
    bei der Routenplanung von A nach B werde ich teilweise über das offene Meer geführt. Das kann ja wohl nich sein.
    Bitte um Hilfe!
    Herko ter Horst Wolfgang Horn 2 Replies Last reply
    • Wolfgang Horn Wolfgang Horn
      Hallo,
      Bitte um Hilfe!
      @Wolfgang-Horn From where to where? If there is a tunnel or ferry service, it will be used.
      Wolfgang Horn 1 Reply Last reply
        Wolfgang Horn
        Wolfgang Horn
        Wolfgang Horn
        @Herko-ter-Horst
        From Bruchsal to Reggio Calabria.
          @Herko-ter-Horst
          @Wolfgang-Horn said in Streckenführung über das Meer:
          It will help if you post a link to your route so that we can take a look.
          Don't forget to set the privacy of the route to 'Public'.
          And indicate the waypoint number where it goes wrong.
          • Herko ter Horst
            Yes, please share your route. If I just create a direct route from Bruchsal to Reggio Calabria, I get what I would expect, a route that looks like this:
              Hallo,
              Bitte um Hilfe!
              Wolfgang Horn
              Wolfgang Horn
              Wolfgang Horn
              @Wolfgang-Horn
              Hallo,
              hiere is my screenshot.
              -TomTom gold street map
              -No highway.
              Thanks!
              TorqueRider Herko ter Horst MotoCon 3 Replies Last reply
                @Wolfgang-Horn
                Hallo,
                -No highway.
                Thanks!
                @Wolfgang-Horn
                We didn't ask for a screenshot?
                  @Wolfgang-Horn
                  Hallo,
                  -No highway.
                  Thanks!
                  @Wolfgang-Horn There is a ferry service from Salerno to Messina on Sicily (followed by a ferry from Messina to Reggio Calabria) which apparently TomTom thinks will take you there faster than using secondary roads over land. If you also tell MRA to avoid ferries, you'll get a fully overland route. Or just add more waypoints.
                    @Wolfgang-Horn
                    Hallo,
                    -No highway.
                    Thanks!
                    @Wolfgang-Horn, The trick is in the "No Highway". If I force the route over land, I need two extra waypoints, and the route-time increases by over 2,5 hours. So, it seems by boat is quicker than over land if you avoid highways in that area. According to the TomTom map anyways...
                    • TorqueRider
                      @Con-Hennekens @Herko-ter-Horst
                      I think it would be a good idea if TS delves into creating a route? Why doesn't a route do what you want if you only put two waypoints on the map?
                      Ich denke, es wäre eine gute Idee, wenn TS sich mit der Erstellung einer Route befassen würde? Warum macht eine Route nicht das, was Sie wollen, wenn Sie nur zwei Wegpunkte auf der Karte platzieren?
                      Anleitung 'Eine neue Route erstellen'
                      • TorqueRider TorqueRider
                        Wolfgang Horn
                        Wolfgang Horn
                        Wolfgang Horn
                        @Jack-van-Tilbue93ac0ee-77ec-41db-b7ad-d1645f039de8-grafik.png rg [link text](link url)
                        • Wolfgang Horn
                          Wolfgang Horn
                          Wolfgang Horn
                          https://www.myrouteapp.com/de/social/route/8543515?mode=share
                            @Wolfgang-Horn
                            Thank you very much! 🙂
                            You cannot create a route with only two waypoints if you want to avoid certain parts.
                            Do as mentioned above by @Con-Hennekens and add more waypoints.
                              @Wolfgang-Horn
                              Wolfgang Horn
                              Wolfgang Horn
                              Wolfgang Horn
                              @Jack-van-Tilburg thank you!!!
                              Wolfgang Horn
                              Wolfgang Horn
                              • Real-time traffic
                                Andy Nicholson
                                Andy Nicholson
                              • HERE map not calibrated
                              • Myrouteappstay
                              • Navigatie met DMD tablet
                              • Show on the maps's button
