  4. MotoButtons Lite DIY project!
52 Posts 10 Posters 38.4k Views 3 Watching
    For the DIY freaks
    MotoButtons Lite
    A low cost, waterproof, Bluetooth (BLE) controller for Drivemode Dashboard motorcycle navigation with joystick and mouse mode for only $28 in parts.
    https://github.com/joncox123/MotoButtons?
    I am not sure, I have to read all information, and maybe it will work with MRA as well.
    I let you know.
    • Leo Klein
      Leo Klein
      Leo Klein
      i want to make one if it works
      KTM 1290 Super Adventure S, Samsung Xcover 6 Pro, Google Pixel 8 Pro, Carpe Iter Controller, Android Auto
      • richtea999
        Good spot Jörgen!
        His attention to detail in the Construction guide page is second to none, and a comprehensive parts list too.
        I see he has the same issue as Joost at BarButtons (and no doubt others), i.e. the price of the 5-way joystick/thumbstick - waterproof ones are very expensive.
        However, he offers excellent alternative for waterproofing it yourself.
        Oh, but only a KTM rider would fit it on the throttle side, right?
        Jörgen MotoCon 2 Replies Last reply
        • richtea999 richtea999
          Good spot Jörgen!
          @richtea999 said in MotoButtons Lite DIY project!:
          Oh, but only a KTM rider would fit it on the throttle side, right? 😂
            Good spot Jörgen!
            I guess that depends on whether you drive left or right? 😉
            • joncox
              joncox
              joncox
              Hello, I'm the author/creator of MotoButtons. I added support for cycling through multiple modes of operation, including a new one for MyRoute App.
              I tested it out on the Android app, and it seems to work OK. It supports the same functionality as BarButtons, but the 8th button is a "virtual" button activated by long pressing the center joystick button.
              Briefly, the key mapping is up/down/left/right arrows, 'c', '-', '+' and 'n' (vitual). The virtual button pulls up the menu.
              • joncox joncox
                @joncox Hi, you read my suggestion, and you have it already implemented.
                That is great, thank you very much. 👍
                My parts will arrive tomorrow and I hope I can finish the MotoButtons over the weekend. I will let you know the result.
                • joncox joncox
                  @joncox, great that you are here! 😉 As I understand it, you open the menu using a press-down on the joystick. Does that same method also activate the menu option you select? That would probably explain why two buttons are enough.
                  Another suggestion would be to make a longpress on one of the buttons switch from zooming +/- to volume +/-
                  I am interested, I will look into your project for sure!
                  • Jörgen Jörgen referenced this topic on
                    So MotoButtons is ready and with some little changes working with MRA.
                    Zooming in/out, open menu etc. works fine.
                    I am not sure which mode I like more (mouse or BarButtons), I need to have praxis test.
                    Anyway thanks to Jon for this great project, I like it. 👍
                    MartinW 1 Reply Last reply
                      @Jörgen Can we have some pics, please! 👏
                        @Martin-Wilcke Looks like this one.
                          @Corjan-Meijerink I build the MotoButtons and they work fine so far. The author made some changes already to improve the function.
                          But they are not perfect, or may be I did something wrong.
                          The MotoButtons are in BarButton mode as well as MRA. Moving map, zoom in out are ok, long press on the joystick Center open menu or Center map. If I am in the menu, I can move up down, but how to get out of the menu? What command is needed, or how does the BarButton do this? With another button? And how is the skip waypoint working, also with another button?
                          May be a BarButton owner can help.
                          richtea999 1 Reply Last reply
                            @Jörgen The BarButtons codes are here:
                            https://jaxeadv.com/barbuttons/using-the-barbuttons/barbuttons-user-guide-v4/
                            The default keymap for MRA is Keymap 1:
                            And here's the specific info on what Keymap 1 does in MRA:
                            https://jaxeadv.com/barbuttons/compatible-applications/#htoc-m
                            So, combining those two together, to leave the menu you need to generate an 'N' = close drawer. Which on BarButtons is button 3.
                            Let us know how you get on!
                              Here a video that explains the problem:
                              https://youtu.be/UYnIyIdnH_o?si=aScruJCCABUo3m7Q
                              joncox 1 Reply Last reply
                                joncox
                                joncox
                                joncox
                                wrote on last edited by joncox
                                @Jörgen I think the problem is due to keyboard layout locale in Android and iOS. I changed the "keyboard layout" from US English to German in Android 10, and I reproduced the problem you said you had on iPhone (minus key becomes "/" key).
                                Your problem is different on Android, however, I am almost certain it is still a keyboard layout problem. You have to also set the "keyboard layout" for the MotoButtons to US English. This will only effect the MotoButtons controller, not the rest of your system.
                                https://www.mobilefun.co.uk/blog/2015/04/how-to-fix-bluetooth-keyboard-language-settings/
                                https://support.apple.com/guide/iphone/add-or-change-keyboards-iph73b71eb/ios
                                In hindsight, I think MRA should use keys that do not change with different keyboard layouts. In other words, using n, c, +, - is probably a bad idea. However, on a US full sized keyboard, there are two minus keys. Maybe if I send the other one, it will work correctly on US and German layouts. I wasn't sure originally which one to send.
                                Lastly, in KeyEventDisplay, I noticed that holding down the center button does not release the key until the button is released. This is the proper behavior in DMD2, but it triggers the internal key repeat in Android. Again, the latest firmware is working correctly for me on iPhone and Android with US layout, but maybe this is also causing an issue on your Android tablet. I could try disabling the repeat for center button long press.
                                By the way, I am not studying the BarButtons code because I don't think he has released it as open source. So I am not looking at it to avoid any potential copyright questions.
                                  HI, I changed the keyboard layout as you said, but get still the black screen like in the video.
                                  But I noticed something, when I do a long press (1-2sec.) on the center button, the first white LED is flashing. If I release the pressure then, the menu opens normal, if I press longer then LED flashing I get the black screen.
                                    Hi, I think we got a little further and were able to pinpoint the problem a little more precisely. It has nothing to do with the keyboard layout.
                                    The MotoButtons send key signals to MRA (n, c, +, -, left, right, up, down).
                                    During testing, I had Google open and cold see what keys were sent to my tablet. You could see +, -, for the zoom buttons, you could see c for the center button, and you could see n for long press center and on longer press nnnnnnnnnn.
                                    But as shown in the video, if you press n too long in MRA, MRA crashes.
                                    The first Idea was that is an issue of the MotoButtons, then I had the idea to use a Bluetooth keyboard in MRA (in BarButton Mode).
                                    Everything worked as expected, except when I press n longer, MRA crashes.
                                    So I can get the same problem, like in the above video with a BT keyboard.
                                    @Corjan-Meijerink can you take a look into this?
                                      @Jörgen I've replied to the email thread.
                                      The issue regarding long pressing that character has been fixed for the next (beta) update.
                                      Jörgen 1 Reply Last reply
                                        @Corjan-Meijerink Ok, thank you, saw the mail.
                                        So you think that this and the other issue with BT connection have the same cause?
                                        I will report after next update. 👍
                                          @Jörgen the connection crash seems very weird and not reproducible on any of our Androids / iPhones 🙂 Could be your device, could be the tablet or something else 🤷
                                          Hubert Thoring Jörgen 2 Replies Last reply
                                          • 3
                                          Leo Klein
                                          Leo Klein
                                          Robert Jeffries
                                          Robert Jeffries
                                          joncox
                                          joncox
                                          harupipapaZZZ
                                          harupipapaZZZ
                                          • How to change from KM to Miles?
                                          • Replies in this section
                                          • Split route - how to view all days together?
                                          • Gegevens Overnachting
                                          • Change name of stays
