  4. pop-up <Move-Save as-Delete> doesn't show (solved)
30 Posts 7 Posters 10.9k Views 2 Watching
    @Drabslab, certainly true, but I think it's about more than 2 companies. Apple, Google, Microsoft, Meta and many many more companies are no popes in the subject.
    Drabslabundefined Offline
    Drabslab
    and there is a difference between "not being a pope" and being fined 8.3 billion euro for slightly illegal activities 🙂 🙂 🙂
    • Drabslabundefined Drabslab
      #22
      @Drabslab, I believe Apple is still subject to a 39 billion fine... 😉
      Oh, and do you really think Apple does NOT sell off bigdata? Users are clients indeed, AND the product at the same time. I am not downplaying the privacy problems. But don't pin them just on Google and Facebook. The other are equally evil...
        Drabslab
        @Con-Hennekens said in pop-up <Move-Save as-Delete> doesn't show:
        turn to the dark side.... we have coockies 🙂
        • Jörgenundefined Jörgen
          Maybe this will help.
          https://youtu.be/cOEGPExqgTU
          By clicking on a folder, the box just flashes and disappears.
          Jack van Tilburg
          @Jörgen
          Yep. That's what it actually looks like.
          Big thanks for this video!
          • Herko ter Horstundefined Herko ter Horst
            @Jack-van-Tilburg Same issue here (latest software versions): when selecting an item, the actions box pops up very briefly.
            I've looked into the code a bit, stepping through it in the debugger, and I've noticed the pop-up becomes visible when, on line 473 of base.js, the CSS class "in" is added to the ".explorer-selectedactions" block. However, it immediately becomes invisible again as well, when stepping over this line. I can only assume a different part of the code reacts to the addition of the "in" class and changes the CSS to make the pop-up invisible, or perhaps the z-index isn't handled correctly by Apple. The "in" class is on the box when inspecting the element.
            Just noticed it also popups very briefly when deselecting a previously selected row.
            It only happens when selecting the first (or deselecting the last) item.
            Jack van Tilburg
            @Herko-ter-Horst said in pop-up <Move-Save as-Delete> doesn't show:
            This is beyond my knowledge 🙂
            But hopefully the technicians can do something with it 👍
              @Herko-ter-Horst perhaps Safari is more strict in the handling of those pop-ups then other browsers do?
              Jack van Tilburg
              @Rob-Verhoeff said in pop-up <Move-Save as-Delete> doesn't show:
              That's definitely true. But Safari also offers the option to cancel the pop-up blocker in the settings.
              Herko ter Horstundefined 1 Reply Last reply
                @Jörgen said in pop-up <Move-Save as-Delete> doesn't show:
                The video seems to be private, I can't watch it.
                @Jack-van-Tilburg said in pop-up <Move-Save as-Delete> doesn't show:
                It is up to the developer to make the application function browser independently. And I know that's difficult.
                It's up to the developer of a browser to make it compliant too. All software contains bugs. It's too easy pointing only at MRA, while Safari seems to be the only browser having this problem. Although of course it still may be an MRA bug, it is as easy to point it to the Safari browser.
                Jack van Tilburg
                That is absolutely correct.
                For that reason, beta versions are made available to developers well in advance so that they can test whether their stuff still works. If there are issues, then something must be done. And depending on the test result you can determine where that is.
                  Regarding safety, I think all "major" browsers have that in order
                  You think that Google spyware is safe?
                  https://www.forbes.com/sites/zakdoffman/2021/03/20/stop-using-google-chrome-on-apple-iphone-12-pro-max-ipad-and-macbook-pro/?sh=69a169514d08
                  https://www.bleepingcomputer.com/news/security/chrome-use-subject-to-restrictions-in-dutch-schools-over-data-security-concerns/
                  Rob Verhoeffundefined Online
                  @Drabslab said in pop-up <Move-Save as-Delete> doesn't show:
                  Well, in that case... I'm glad I said "I think...". So I guess not 😁
                  BMW K1600GT-P (2013) | Nolan N100-5 with Sena 30K
                  iOS on iPhone 13 & 16 (mounted on Quadlock or AliExpress extention on BMW-cradle)
                  Apple CarPlay in VW T-Roc
                    Herko ter Horstundefined Offline
                    As I expected, this changes nothing w.r.t. this issue. From what I can see, it's not an actual pop-up.
                      Who recognizes this and knows the solution?
                      When using the checkbox to select multiple items in the personal library for an action <Move|Save as|Delete>, a pop-up will appear to activate that action.
                      On my iPad (7th gen), iPadOS 17.03 and on my MacBook (M1Pro) with MacOs Sonoma 14.0 in combination with Safari 17.0, the Pop-up flashes but disappears in a fraction of a second and cannot be used. I have set all settings in Safari for additional functions for Myrouteapp to "Allow". Without exception.
                      When using Firefox I do not have this issue. But I want to use Safari exclusively.
                      Jack van Tilburg
                      I switched back to my favorite browser Safari and now see that this issue has been resolved.
                      Unfortunately, a new problem has arisen. But I still have to work up the courage to describe that.
                      Jörgenundefined
                      Jack van Tilburgundefined
                      Jack van Tilburg
                      Drabslabundefined
                      Drabslab
                      • 3rd device - cannot delete it
                      • MRA 5.1.0 (458) Routenoptionen werden nicht berücksichtigt
                      • Rondreis Schotland en VK
                        Alida Veenstraundefined
                        Alida Veenstra
                      • MRA V5.1.0 (458) afstand naar tankstation niet correct met Android auto
                        Leo Kleinundefined
                        Leo Klein
                      • Route niet te starten op MRA Mobiel
                      • Layers, stack routes on POI maps
                      • Demande de paiement d'abonnement quand je veux démarrer mon itinéraire
                        Olivier Decock 1 0undefined
                        Olivier Decock 1 0
                      • Waypoint met foto
                        Robinekeundefined
                        Robineke
