Which map is used on mobile
I wonder, which map is used in the new mobile App MyRoute-app. As I see, I can chose a map in settings when now route is planned or loaded, but when there is a route in the app, it seems to be the Here map, and I don't see if I can change it anywhere to OSM or Tom-tom.
It is also a question, which map is downloaded for offline routing.
Thank you,
Csaba
Thank you,
Csaba
@Csaba-Trenger That would be HERE!
In the first screen you see when opening the app you can choose any map layer you like (as in the website) but when navigating, you use HERE. The offline maps are therefore also HERE.
This because the app is built on HERE software.
@Corjan-Meijerink Thank you, it is clear now
With your input, this post could be even better π
