  4. Newbie needs help opening HERE map in app...
24 Posts 6 Posters 10.3k Views 2 Watching
  • richtea999 richtea999
    @Tom-Grzelinski said in Newbie needs help opening HERE map in app...:
    @Rob-Verhoeff
    Again, thanks Rob, I will look at multi-day trips.
    There's a 'Split' option available to Gold users - it's in the Toolkit menu. A lifesaver after putting all that effort in!
    All you have to do is select the waypoints where you want to split the route up. It won't overwrite your existing route, so you can experiment without risk.
    Tom Grzelinski
    Tom Grzelinski
    Tom Grzelinski
    @richtea999
    Hi Rich, THANK YOU. This worked perfectly πŸ‘
    Tom
    Porsche 911 and VW Transporter T6.1 running CarPlay.
    iPhone 17 Pro running Waze and MRA.
    MRA Routeplanner on web via Mac
      @Tom-Grzelinski I did a little more testing. I'm not able to open the entire map but I split the map into two half's and I'm able to open each half. I'm also able to start navigation as long as I quickly turn off the option to navigate from current location (can't navigate from Canada 😊 ). So the end result is that I don't know why the app can't open the entire route ... other than it is simply too large. I had a similar problem when planning a 2 week trip. Once I was finished planning on the Web site I split into separate routes for each day. Good luck.
      Tom Grzelinski
      Tom Grzelinski
      Tom Grzelinski
      @Doug-Robinson
      Doug, thank you so much. I successfully SPLIT my route in to 13 days and each one opens perfectly in the iPhone app.
      I am indeed navigating a lot of Apline passes that are often closed. I am hoping that going in September will mean I can do all the passes I intend to, but I have seen photos that there is already snow on the Grossglockner Pass!
      Tom
      • Tom Grzelinski
        Tom Grzelinski
        Tom Grzelinski
        The more I use MRA, the more impressed I am. Well done to the team MRA πŸ‘
        • Tom Grzelinski Tom Grzelinski
          @Tom-Grzelinski we keep pushing πŸ’ͺ
          Tom Grzelinski
          Tom Grzelinski
          • My Routeapp Stays questions
          • Foutmelding In MRA Next
          • Strange translation
          • Kort voorstellen
