  4. Map not following arrow
5 Posts 3 Posters 1.6k Views
  • Martin Keen
    Martin Keen
    Martin Keen
    The map doesn't follow the arrow/pointer the map iremains on the first section of the route. Although the directions are still showing in the corners.
    I am using an android phone and have checked all the settings.
    Also the old navigation app us still working should I be using this?
    Herko ter Horst Con Hennekens 2 Replies Last reply
    • Martin Keen Martin Keen
      @Martin-Keen said in Map not following arrow:
      This can happen if you've (accidentally) moved the map yourself, even slightly. Does it go back to following if you tap the compass?
      The old navigation app is no longer being maintained. You can use whatever you want, but the future of MRA Navigation is with the new app.
      Martin Keen 1 Reply Last reply
        Martin Keen
        Martin Keen
        Martin Keen
        @Herko-ter-Horst OK thanks iwill have a go this afternoon 👍
          Martin Keen
          Martin Keen
          Martin Keen
          @Martin-Keen Hi that seemed to work 😊
            @Martin-Keen, The old app still works yes, but not for very long. HERE is pulling the plug out of the platform it was built on.
            Martin Keen
            Martin Keen
            • Animation
            • Help please, new user
              Doug Crocker
              Doug Crocker
            • A04 Menu - Waypoints on the mobile phone
            • Route line transparency
