  4. Homograph s. Lösung für das IPhone
44 Posts 13 Posters 24.0k Views 4 Watching
    We will support different voices in a future (not known schedule) update. Now the default voice for the text-to-speech engine is the only one we support.
    Drabslab
    Drabslab
    Drabslab
    @Corjan-Meijerink said in Homograph s. Lösung für das IPhone:
    it would be nice to have a voice that can cope with place names a bit better. Its very often totally impossible to guess from the audio what city/street/place the voice is actually intending to say
    • Matt Matt
      @Jörgen said in Homograph s. Lösung für das IPhone:
      For your information, iOS Version 16.5.1 (c) from today still has this problem.
      Just tested iOS 16.6. The „Homograph“ is still alive! Oh what a pitty
      @Matt If you had Ver. 16.6. 21 days ago, can you already test iOS Ver. 17? Where it should be removed.
      • Tom Johann
        Tom Johann
        Tom Johann
        Ich benutzte iOS 16.6
        Das "Homograph"-Problem nervt wirklich! Hinzukommt, die Lautstärke bei gleichzeitiger Nutzung des Cardo-Intercom lässt wirklich sehr zu wünschen übrig.
        Ich frage mich allerdings schon, warum das Problem bei Google Maps und sogar in der alten MRA Navigation-App nicht besteht? Die alte MRA Navigation-App habe ich noch installiert. Diese funktioniert einwandfrei OHNE "Homograph".
        Aus meiner Sicht sollte MyRouteApp hier schon etwas tun können?
        Was meint ihr hierzu?
        Viele Grüße.
        Tom
        • Tom Johann Tom Johann
          Viele Grüße.
          Tom
          @Tom-Johann, funny detail: my Google Maps showed the EXACT same problem concerning the loudness of the voice... If not playing music, you just turn up the volume of the radio/headset, but when playing music that is of course no option. Then if an instruction is given, the music ducks, but the voice is still not loud enough to overcome the music. GMaps showed the exact same thing during my holiday (I used it in my car, BT connected to my car radio).
          The Homograph error is already established to be a problem in some IOS versions. The old app (and many other nav apps) has it's own internal speech synthesis. The new app relies on the OS for that. I am not sure whether the voice instruction itself originates from the app or from the HERE platform. It likely contains some intonation data that gets misinterpreted by the IOS speech synthesis. The MRA devs or the HERE devs could probably strip those, but that would mean loss of voice quality for everyone. Having an own embedded speech synthesis would likely be more flexible, but probably not easy to combine with the HERE platform. It is a chosen direction that is likely not easy to change. Google around, or search for earlier messages in this forum. There seem to be IOS voices that do not show (or speak) this problem.
          Jörgen 1 Reply Last reply
            As written somewhere from me, the TT GoRide-App had the same problem with Homegraph and they fixed it internal (without an Apple update).
            But hopefully Apple will fix it with iOS 17.
            • Con Hennekens
              @Peter-Schiefer, I think you need to realise it is not my software 😉 I have no affiliation with MyRoute-app.
              Gestern nach dem Update auf 4.04 wo eine neu Stimme angekündigt wurde gehofft das Homograph Problem sei gelöst.
              I am not aware of a new voice, but yes improvements have been made to how voice guidance is given. Not on the voice itself, that's an OS thing. I am not denying something could perhaps be done by MRA to prevent the homograph problem, but you need to realize it is ultimately an IOS bug. It is entirely possible that other companies, with undoubtedly a larger dev team, have found a workaround for it. I heard recently that also TomTom has the same problem. Why not ask the bug-owner to solve the bug? In the meantime, what I understood from other users using IOS, the problem is solved by choosing a different voice in your IOS settings. You will find details by searching in this forum.
              Immer wieder meldet MyRoute App ohne dass es geöffnet ist, einen Absturz auf dem iPhone?
              I have not heard this before. Best thing to do is to send some crashreports to the dev team, along with a description of the problem (at what time it happens and under what circumstances).
                Das Update auf iOS 17 soll im September kommen und das Homograph Problem beseitigen. Ein Wechsel zu einer anderen Stimme ändert nichts. Also warten...
                Oder die Jungs machen es wie der andere Holländische Mitbewerber und ändern es in der App.
                  @Jörgen : Danke für die Info ❗️
                    Das iOS 17.0 steht jetzt zur Verfügung
                      @Hubert-Thoring Und schon probiert?
                      Mopetenpit Hubert Thoring 2 Replies Last reply
                        Mopetenpit
                        Mopetenpit
                        Mopetenpit
                        @Jörgen ja, jetzt funktioniert es!!😁
                        • Mopetenpit Mopetenpit
                          @Mopetenpit Hurra, Hurra der Homograph ist tot. 😁
                          Aber nicht zu früh freuen, er war auch mal in einer früheren Version weg und kam mit einem weiteren Update zurück.
                          Aber gut zu wissen, jetzt muss nur noch iOS 17 keine Fehler enthalten, dann geht es entlich mit Ton weiter. 😉
                          • Tom Johann
                            Tom Johann
                            Tom Johann
                            Soeben kam das Update von Apple auf iOS 17.0 auf mein iPhone 12.
                            Das Homograph-Problem hat sich erledigt!! Das ist wirklich TOP!
                            Danke für die Unterstützung und die vielen Erklärungen 😉
                              @Jörgen :
                              @Drabslab
                              @Manfred-Hauser-0
                              @Matt
                              @Mopetenpit
                              @Nick-Carthew
                              @Peter-Schiefer
                              @Rob-Verhoeff
                              Guten Morgen in die Runde, ja gestern ausprobiert, über 240km und das Thema Homograph ist jetzt nach dem iOS Update auf 17.0 erledigt.
                              Gleichzeitig hatte ich heute das Gefühl das die Audioqualität im Zusammenspiel mit den gekoppelten Geräten wie Handy iPhone Xr, Sena S3, BMW Cradel und BMW TFT jetzt etwas klarer und deutlicher ist, vielleicht weil MyRoute-App ja jetzt auch einen anderen Audiokanal nutze seit dem letzten Update.
                              Danke an alle die daran aktiv mitgearbeitet haben !!
                              VG 👋
                                Mir wird auf meinem iPhone X noch kein Update angeboten. 😢
                                Hubert Thoring Mopetenpit 2 Replies Last reply
                                  @Jörgen : iPhone suchen lassen
                                  Unter …. / Einstellungen/ Allgemein / Softwareupdate / …
                                    Mopetenpit
                                    Mopetenpit
                                    Mopetenpit
                                    @Jörgen Ich glaube, da musst du mindestens das Model "XS" für iOS 17 haben...
                                    Hubert Thoring Jörgen 2 Replies Last reply
                                      #38
                                      @Mopetenpit : ich habe das iPhone Xr (war mal günstiger als das X 😉) damit habe ich auch das Update bekommen 👋
                                      @Jörgen : du scheinst jetzt Pech zu haben schau mal was unten steht ..
                                      Mopetenpit 1 Reply Last reply
                                        Mopetenpit
                                        Mopetenpit
                                        Mopetenpit
                                        @Hubert-Thoring ja, das ist richtig. Das "XR" kam auch nach dem "X" raus. Das "XR" und "XS" kamen 2018 auf den Markt, das "X" in 2017.
                                          Watch out with spamming that letter.
                                          Musk might come after you 😉
                                          • 3
                                          Drabslab
                                          Drabslab
                                          Reinhard-32
                                          Reinhard-32
                                          Mopetenpit
                                          Mopetenpit
                                          Tom Johann
                                          Tom Johann
                                          Manfred Hauser 0
                                          Manfred Hauser 0
                                          Matt
                                          Matt
                                          • Routenplaner on iPad
                                          • New Zealand Routes
                                            Bull Tahr
                                            Bull Tahr
                                            J2FK
                                            J2FK
                                          • MyRouteApp (WebPlanner) development Roadmap
                                            Philipp Kühn
                                            Philipp Kühn
                                            6.2k
