  4. Am I doing something wrong?
5 Posts 3 Posters 123 Views 1 Watching
  • ferrand24gmail.com
    ferrand24gmail.com
    ferrand24gmail.com
    Planned a route and downloaded it for offline use and selected it from my downloads.
    When starting to navigate a notice said "can not calculate offline. Go online?" I could do this because I was still at home and within wi fi range. This done, it worked perfectly for the whole route. However if I had not been within wi fi range initialy it would have been unuseable.
    I notice that some offline problems have been corrected for the public release so maybe it's been taken care of.
    • ferrand24gmail.com ferrand24gmail.com
      @Roger-Doidge Perhaps a silly question, but have you also downloaded the map(s) for the region through which your route passes?
      ferrand24gmail.com 1 Reply Last reply
        ferrand24gmail.com
        ferrand24gmail.com
        ferrand24gmail.com
        @Rob-Verhoeff I've never been prompted to do that,so the answer is no, I haven't downloaded any maps. The route was only about 50 km in my local area.
        I was not aware that specific maps had to be downloaded or how to do that.
        Albert Renting 1 Reply Last reply
          Albert Renting
          Albert Renting
          Albert Renting
          wrote on last edited by Albert Renting
          @Roger-Doidge To download maps onto your device follow these pictures:
          Press the 3 horizontal bars in the top left corner
          Press the icon in the top right corner
          Scroll down to Offline maps
          Download the maps you think you might need.
          This used to take a long time to process, have patience.
          Then you can work off-line when needed
          Good luck!
            ferrand24gmail.com
            ferrand24gmail.com
            Done that, thanks!
            ferrand24gmail.com
            ferrand24gmail.com
            Albert Renting
            Albert Renting
              1.4k
              Anonymouse
              Anonymouse
              1.4k
              2.3k
            • nieuwe gebruikers
            • MRA 6.0.0 (515) Speed / Height Profile /// Geschwindigkeit / Höhenprofil
