  4. Battery drain APP Version 3.2.15 vs 3.2.17
4 Posts 3 Posters 101 Views
  • DerRoteBlitz
    DerRoteBlitz
    DerRoteBlitz
    Re: Battery drain when navigating
    Dear MRA team,
    first I would like to mention that you are currently providing a great piece of software! Many thanks!
    Regarding the issue.
    Hardware: Pixel 7 Pro, Android 13, SPC+ wireless charger
    I am testing since a few versions. With the version 3.2.15 I could run MRA Next online navigation (A2B or a route), a second software checking the GPS, listen to music and do some phone calls. No problems with power. I could charge the battery and have not seen any power issues.
    With the version 3.2.17 unfortunately the other way round. Not able to charge the phone, (after restart, only MRA Next active) and still draining the battery. Without MRA Next active the phone is charging as expected.
    Please go back to the power consumption of version 3.2.15... ๐Ÿ™‚
    Thanks
    • DerRoteBlitz DerRoteBlitz
      Dear MRA team,
      Thanks
      @DerRoteBlitz, Some things have been done to improve battery usage mainly on IOS device. I have not noticed any different battery usage on my two Androids. The most used IT solution: could you restart your device (completely) and see if the problem sticks?
      DerRoteBlitz 1 Reply Last reply
        DerRoteBlitz
        DerRoteBlitz
        DerRoteBlitz
        Hello,
        I did that already, does not solve it.
          Dear MRA team,
          Thanks
          @DerRoteBlitz Thanks for the compliment! ๐Ÿ™‚
          We have reached out to HERE regarding the battery usage. On our side nothing has changed between the different Beta versions. We hope to fix this issue in the near future!
          DerRoteBlitz
          DerRoteBlitz
          • The menu option โ€œContinue with your last routeโ€ is missing
            Axel Lange
            Axel Lange
          • In het kort......
          • Route probleem
            Jack 13
            Jack 13
