  4. Error centering the route
11 Posts 4 Posters 123 Views 2 Watching
  • Òscar
    If for any reason I move the route indicator (in this case to show the global route), when I want to re-center the cursor it stays very off-center.
    https://youtu.be/TKSkj7grr_c
    • https://t.me/MRa_by_b0hd1
    • YouTube: @demco17
    Rob Verhoeff Corjan Meijerink 2 Replies Last reply
    • Òscar Òscar
      This post is deleted!
      Òscar 1 Reply Last reply
      • Òscar Òscar
        @b0hd1 that looks incorrect indeed! Thanks for sharing 🙂
          I had the same. But with opening the menu and close it, the arrow was back in correct position.
            [[topic:post-is-deleted]]
            @Rob-Verhoeff Can you watch the video?😉
            • YouTube: @demco17
            • Òscar Òscar
              @b0hd1 seen it 👍 Weird!
                @Corjan-Meijerink Randomly, it keeps failing when I pinch or move the map with my fingers. When I center it using the "compass" icon, it doesn't stay centered. I tap on options (three dots in the bottom right) a couple of times, and it centers correctly again.
                • YouTube: @demco17
                • Òscar Òscar
                  @b0hd1 the issue as shared in the video should be fixed in the latest update!
                    @Corjan-Meijerink Unfortunately, today I tried the latest update and it's still failing. Less than before, but it's still failing.
                    • YouTube: @demco17
                    • Òscar Òscar
                      @b0hd1 at this point I honestly have no clue what you mean with “failing” 😞
                      Please elaborate what you are talking about
                        @Corjan-Meijerink Taking advantage of the opportunity of a long morning journey, I conducted several tests, and it hasn't failed again. It was possibly just an isolated incident yesterday.
                        • YouTube: @demco17
                          Axel Lange
                          Axel Lange
                        • In het kort......
                        • Route probleem
                          Jack 13
                          Jack 13
