  4. Wird langsam gut!
Wird langsam gut!
5 Posts 4 Posters 57 Views 1 Watching
  • Kudee
    Kudee
    Kudee
    Navigation in der Garage gestartet. Routen Berechnung ok, kaum draussen "Kein Internet Empfang". Das ist definitiv noch ein Bug.
    Gewollt Route nicht gefahren und mich navigieren lassen. Top, keine Abstürze. Nervig ist der Kompass der jedes Mal gecklickt werden will wenn Routenpunke manuell übersprungen werden!
    Gestartet mit 35% Batterie, Retour 53%. Samsung P30Pro mit Wireless Charging.
    Kommt gut! Danke an die Entwickler
    • Kudee Kudee
      @Kudee thanks for sharing 🙂
      We should not forget where we come from and definitely not where we are going! 💪
      • Kudee
        Kudee
        Kudee
        This post is deleted!
          Wieso Kompass? Ich tippe den Wegpunkt bzw. die Nr. Oben an um einen WP zu überspringen.
          • Kudee Kudee
            @Kudee, If you have downloaded offline maps you should be able to navigate without internet connection. Just when calculating the route it needs internet connection. Of you enable off-line mode AND have maps downloaded AND you download the route in advance, THEN you can start the route completely internet independent. There is work being done to smooth that experience.
            About the Compass, you should not need to tap it regularly. I am afraid you are touching the screen or moving the map slightly by hand. After that you need to re-center the map to your current position (which is done by tapping the compass). The MRA team is working on automating the re-center when movement is detected.
            Kudee
            Kudee
            • New Zealand Routes
              JP d
              JP d
            • Off-road niet zichtbaar in Android Auto
            • IOS 27
              Stephen Rowland
              Stephen Rowland
              wim GS
              wim GS
              2.0k
            • Naar vorig routepunt
            • Getal in begin logo
