  4. Not new, but still annoying
7 Posts 3 Posters 111 Views 1 Watching
  • Jörgenundefined Offline
    When I work on the tablet in landscape mode.
    And want to open the Route lab, I get this.
    Is it possible to change this? To have all screens in landscape mode.
    • Jörgenundefined Jörgen
      @Jörgen The browser is by design forced in portrait when the resolution of the screen in landscape is too low.
      This has been the choice because the website would not work like you would want to in landscape on your tablet. If you really want to, you can always use a browser 🙂
      • richtea999undefined Offline
        Since the web site works OK in landscape, maybe consider embedding the web version into the app instead of having mobile-specific markup.
        You'll need a single-sign-in bit of code, but you'll have less markup/code to support.
          Yes, the browser is an option, but not a good one. There is no browser where you can hide the address bar (I tested different ones), some browser move the address bar up, when you scroll on the website. But the upper part in MRA is fixed, so move up will not work.
          And as you can see the upper part takes 1/3 of the total screen and the video slider takes also a lot of the screen. The map part is very limited.
          If you could reduce the Menu part to the minimum, there will be more space for the map.
            There is a little improvement when you switch to Desktop-Mode.
            For your information, this is with FireFox!
              And that’s exactly why portrait mode is forced for tablets with your resolution 😉
              And really, you don’t need to enter the browser when your tablet is mounted 🙂 So just take it out and use portrait.
              But indeed, the website could be improved a lot regarding this so yes, that is for the future!
                Ok, also good to know that this is recognized. 👍
                richtea999undefined
                Jörgenundefined
                  Axel Härtlundefined
                  Axel Härtl
                  2.4k
                • seizoen afsluitingen
                • Poi's per rit op meerdaagse reizen
                  Jan Weerheimundefined
                  Jan Weerheim
                • Doe ik iets verkeerd of...
                  Michel 71 0undefined
                  Michel 71 0
                  -1
                • MRA V5.2 (473) Change POI name in app
