  4. Car Play routeline and arrow partly hidden
3 Posts 2 Posters 26 Views
  • Koen VH
    Koen VH
    Koen VH
    On the Car Play display of my Opel Insignia the routeline and arrow is in the middle of the screen and is sometimes hidden by the info boxes.
    On the iPhone it is OK.
    While riding the routeline sometimes disappears
    With a left turn ahead the routeline hides itself behind the info box.
    When the arrow positioned a bit more to the right, this problem could be solved.
    Regards,
    Koen
    iPhone SE 2020
    Outikel RT3
    iPhone SE (2020) - Outikel RT3 (Android 12)
    • Koen VH Koen VH
      Regards,
      Koen
      iPhone SE 2020
      Outikel RT3
      @Koen-VH that’s a known issue we still need to fix 🙂
      It only occurs when connecting CarPlay while already navigating (or in the route settings screen before that).
      Solution is to tap any of the buttons bottom right (twice in case of fit route and for the other click “done” after) and then the offset is correct (slightly more to the right) 🙂
      Koen VH 1 Reply Last reply
        Koen VH
        Koen VH
        Koen VH
        @Corjan-Meijerink Hi Corjan, thanks for the hint, I'll try this ASAP. 👍
        Koen VH
        Koen VH
          Axel Lange
          Axel Lange
        • In het kort......
        • Route probleem
          Jack 13
          Jack 13
