  3. How to make satnav flag up my coffee stops?
6 Posts 4 Posters 1.1k Views 2 Watching
  • David MP
    David MP
    David MP
    I have a BMW Nav V (ie Garmin) GPS, and use it with GPX v1.1 files downloaded from MRA. So I use shaping points to define the overall routes, with waypoints set at fixed points where I want to stop, eg for coffee or meal breaks.
    My question - how do I persuade the GPS to display some useful info about the waypoints? Like, their name, or the distance to them? Right now I get nothing, and it's quite common for me to ride straight past waypoints where I'd earmarked a stop. I feel sure I must be doing something wrong?
    TorqueRider Dikke Wim 2 Replies Last reply
    • David MP David MP
      @David-P-0
      I'm afraid that won't work with MRA planner.
      When I still had a Garmin I used Garmin POI Loader for that.
      But that's actually quite a lot of work.
      Dikke Wim 1 Reply Last reply
      • richtea
        richtea
        richtea
        wrote on last edited by richtea
        @David-P-0 would it work if you convert the shaping point into a via point? You can toggle any route waypoint between these two sub-types by clicking the icon in the waypoint menu (see below, it's the hand icon on the second row of icons in the menu).
        If you create it as a via point (where the point is displayed on the map with a hand icon not a "guitar pick" icon), you can configure the Garmin to display distance/time to next and get alerts on arrival.
        • David MP David MP
          Dikke Wim
          Dikke Wim
          Dikke Wim
          @David-P-0
          hij have the same Nation V and always urs the GPX 1.2 format for the simple reason that I then only see (all The) via points and no shaping points.
          • TorqueRider TorqueRider
            @David-P-0
            Dikke Wim
            Dikke Wim
            Dikke Wim
            @Jack-van-Tilburg
            It does work👍 Including the names of the via points that you use in MyRoute App. You have to use the GPX for at for that.
            • richtea richtea
              Dikke Wim
              Dikke Wim
              Dikke Wim
              In addition you can give the via point a name with the upper left icon in the screendump above.
              Dikke Wim
              Dikke Wim
              David MP
              David MP
              richtea
              richtea
                430
              • Statement on map spinning
                1.8k
                Barto
                Barto
