  4. CarPlay iOS issues
CarPlay iOS issues
4 Posts 3 Posters 103 Views
  • Sarah O'Neill
    Sarah O'Neill
    Sarah O'Neill
    So after receiving a CarPlay device for my motorbike, I'll include the link of the device below, I thought i'd try it out and found a few issues, that have been reported,
    1, Is the icons cover the route, as in post https://forum.myrouteapp.com/post/24352 however the fix of using the position buttons don't work once the position triangle has been moved, and when you click done the route rotates 180 degrees and lands the position triangle back in the same place it started from. In my case on the left of the screen.
    2, Track logs not saved, well I say that, there is track log data, I have 2 trackless saved under the name TestRouteCarPlay which was the name of the route, 1 has partial track of the route, the 2nd has no data and has the same location as the other 4 "CarPlay track"'s that magically appeared in my track logs with a tracked distance of 1ft somewhere in Berlin, which is odd as I haven't left the UK today
    3, After my 2nd stop, the Car play didn't resume the route like it did after my 1st stop for coffee
    4, there is no pause track log
    iPhone 13 Pro Max iOS 16.4.1 (a)
    MRA Navigation v1.1.3 Lifetime
    My CarPlay device incase that helps https://www.aliexpress.com/item/1005004530437243.html
    • Sarah O'Neill Sarah O'Neill
      @Sarah-O-Neill so you used the “MyRoute-app Navigation” app? That’s not the Beta we are discussing here 🙂
      Sarah O'Neill 1 Reply Last reply
        Sarah O'Neill
        Sarah O'Neill
        Sarah O'Neill
        sorry for the late reply it looks like I'm not getting email notifications,
        yes your correct, I didn't realise this was the beta channel,
        but I have signed up for the beta access but haven't had the TestFlight invite email,
        I have a 30 day 2k+ mile trip planned at the end of June
          @Sarah-O-Neill, about the beta procedure it is best to open a support ticket. The Beta will go Public 19th of June. So after that date you will be able to use the new app anyway.
          Sarah O'Neill
          Sarah O'Neill
            Axel Lange
            Axel Lange
          • In het kort......
          • Route probleem
            Jack 13
            Jack 13
