  4. MAP downloads continue to be a problem
26 Posts 9 Posters 331 Views 3 Watching
  • Rod Sydenham
    Rod Sydenham
    Rod Sydenham
    When you go to the Google Play store this is what is displayed for "navigation"
    Maybe that should be changed so that a person doesn't think that it is linked to the Beta version of Myroute-App?
    • Rod Sydenham Rod Sydenham
      @Rod-Sydenham when I search Google Play Store I see the followingScreenshot_20230509-132758_Google Play Store.jpg
      • Rod Sydenham
        Rod Sydenham
        Rod Sydenham
        I apologize for not having devoted enough time to have learned all there is to know about the new app. I get (thanks to you) that it is the old navigation app that was initially giving me difficulty. However, as you can see, it is not hard to imagine that this could be the "navigation" part of the new app. It is designated as "Beta" and I am identified as a beta tester. Even the icon is new (as compared to the "old" version hiding behind it.
        All I am suggesting is that its appearance in the Google Play store be changed to reflect reality so that others do not make the same mistake I did.
        Dave J 0 1 Reply Last reply
          @Rod-Sydenham it is a feature of the Play Store where you can ask to be a beta tester for some apps and the Play Store (Google) approves this for the Store and shows you as a tester. However, it can still be down to the developer to further allow you to test beta versions of the app. . You should also be able to withdraw yourself from being a beta tester for the old app from within the app within your 'Manage Apps' within the Play Store. Screenshot_20230509-220435.png
          I am new to Android and learning these kind of things as I go along. This is very different to how iOS Test Flight works.
          Ducati Multistrada V4 Rally
          iPhone 15 Pro
          CHIGEE AIO-6 LTE
          • Dave J 0 Dave J 0
            @Dave-J-0 correct! Android is way different. You can literally become Beta tester for almost every app there is 🙂 This is “open testing” which happens directly in the Play Store
            iOS manages Beta builds exclusively using a separate app store so to say: TestFlight.
            • Rod Sydenham
              Rod Sydenham
              Rod Sydenham
              I did not apply to be a beta tester for the "navigation" app. That was done by MyRoute.
              My issue is NOT that I am a beta tester. The issue is the app is identified as the Beta version which is confusing/misleading if nothing else.
              Let's move on. There are some real issues that are keeping the Navigation portion from the app being acceptable. Especially in offline mode. Let's concentrate on that rather than my insignificant issue.
              Nick Hodge
              Nick Hodge
              Rod Sydenham
              Rod Sydenham
                1.6k
                1.5k
              • nieuwe gebruikers
