  4. Route discarded
Route discarded
3 Posts 2 Posters 74 Views
    Ran into a couple of issues yesterday.
    1. Loaded a route and did a long press in waypoint 4 as my starting point. The screen changed to show me a route from current location to what I thought was WP 4. Turns out I missed the WP with my finger and a point to point route was created to a spot on the map near WP 4 and the route that I had loaded was discarded. Discovered this when I ended up on a dead end road at the end of the route.
    2. In offline navigation, selected a destination on the map, selected curvy Road, but when I went to start navigation I get an error message saying I have to turn off offline navigation to use thus feature. Appears that only a straight route can be selected. Why can't we select a curvy route? I noticed that the allowed options also changes.
      @Doug-Robinson thanks for the feedback.
      1: can you reproduce this? A long press on the map should not insert a waypoint. You do generate a route to a chosen location by long pressing on the map you initially see when opening the app. On that screen you cannot long press a waypoint to select as start as the navigation hasn’t even been loaded yet. First start navigation - from the settings screen or the actual navigation you can long press a waypoint to start navigation from there.
      2: that’s correct. HERE does not support track navigation in offline mode yet 😞 Nothing we can do about that. Route navigation does work in offline mode (which applies to your own routes and the straight curvature setting)
      Cheers
      RetiredWingManundefined 1 Reply Last reply
        Cheers
        @Corjan-Meijerink I went back to see if I could reproduce. You are correct. I must have long pressed on the map before I had started navigation. Long pressing on the map before starting navigation results in a new A -B route and the loaded route gets discarded.
        • Account blocking issue
          Bouke Entundefined
        • Why does route change when connecting to Android Auto?
          Herman Veldhuizenundefined
          KevN1k 0undefined
          KevN1k 0
        • Tracklog fails
          Edwin_Mundefined
          Edwin_M
        • Silverfox C1
        • Displaying POI
          RideToPortugal.comundefined
          RideToPortugal.com
        • Eerste woord ontbreekt
          Ed Lauwerens 0undefined
          Ed Lauwerens 0
