Starting a route without internet connection
Now I was actually able to download maps offline, I came across this little bug (or not yet implemented thingy
)If you have maps downloaded, and downloaded a route for offline use. Then go into profile / downloads and tick the route to start it, the app actually crashes (closes to the background) if the option "Offline navigation" is NOT on. After setting that option to ON, the route starts without problems.
Why can't an offline route not be started if you are online?
@Con-Hennekens I believe this is unrelated. Opening a downloaded route simply opens it in the 'mobile' part. The offline mode of the Navigation module is only applied when initialising / using the HERE SDK (after clicking start).
The crash might be caused due to the same issue which resulted in the quick iOS update Friday evening. That it worked with offline mode enabled is likely a coincidence
@Corjan-Meijerink, Hmmpf.... I guess everything I did yesterday was a bug...
I tried it multiple times, but it seems to work as intended now. -
I tried it multiple times, but it seems to work as intended now.@Con-Hennekens don't sweat it
Honestly the chances of it being related to that issue is quite high. The next update will fix it.
With your input, this post could be even better ๐
