  4. Waypoint info and screen brightness
21 Posts 3 Posters 125 Views 1 Watching
  • Bart De Medts
    Two reports:
    1. When I drive a route, it does not always succeed in displaying the info behind certain waypoints by simply clicking on the waypoint. Sometimes it works, sometimes it doesn't. And is it normal that the photos associated with the waypoints are not displayed in the app?
    2. While navigating, my phone screen sometimes dims a bit. It is subtle... and the phone settings indicate that the screen brightness is at maximum, but in reality it is not. Why the screen dims I don't know, I think it's a bug. Am I the only one? I've experienced it a few times.
    • Bart De Medts Bart De Medts
      Two reports:
      @Bart-DM thanks!
      1: only waypoints with a description and / or images can be opened to display more info.
      2: sounds like something the phone does - possibly a side effect of the battery drain (to prevent heating issues)
        @Bart-DM thanks!
        1. I understand that. However, I discovered that when you open a route en start navigating in Next the function does work, but if you close the route back and then reopen (or another one) it no longer works.
        2. Ok, but maybe other people have noticed this too?
        Corjan Meijerink UltraStar 2 Replies Last reply
          @Bart-DM aha, that sounds like a problem! I did not read it like that the first time 🙂 Do you have an example of a route where I can reproduce the issue with? Please let me know what waypoint it applies to.
            @Corjan-Meijerink I only just discovered it myself. It occurs on all routes and at all route points that have info behind them.
            The first time, it works. After that, not unless you restart the app.
              @Bart-DM aha! I got it now too 🙂
              Isn't related to the waypoints - it's another problem. Try opening and closing the navigation menu 😉 Clicking the waypoint after that does work!
                @Corjan-Meijerink Yes you are right! 😀
                  @Bart-DM probably know how to fix it already but Sunday evening isn’t the time for that 😉 Thanks for all your reports and continuous effort to make the app better.
                  Bart De Medts 2 Replies Last reply
                    @Corjan-Meijerink Haha, you're welcome 😊
                      @Corjan-Meijerink I assume it is normal that the photos are not shown in the app?
                        @Bart-DM waypoint photos should be displayed
                          @Corjan-Meijerink I don't see the photos in the app. Can you check this route? Most of the yellow waypoints have a photo...
                          https://www.myrouteapp.com/nl/social/route/7247040?mode=share
                            @Bart-DM I also don’t see them. Waypoint images as visible in the routeplanner are also shown in the app. When images are present, the app will also show them in the route info screen (the one you see when clicking the url).
                            Try this one: https://www.myrouteapp.com/route/open/6227367
                              @Corjan-Meijerink Yes here I see them. Any idea what could be wrong?
                                @Bart-DM no idea 🙂 You see the images in the routeplanner?
                                It’s a nice route! Just been there as you read 😉
                                  @Corjan-Meijerink yes i see them in the routeplanner. Thx, nice route you forwarded too by the way 😊
                                  Perhaps interesting to know... I copied the route from the Xperten library and adapted it myself. So the photos were not added to the route by me.
                                    @Corjan-Meijerink Please ignore my post about the pictures. For some reason there are no more photos in the route I was talking about. Just tested and when I add a photo I see it in Next 😉
                                      @Bart-DM happy it’s sorted! 🙂
                                        @Corjan-Meijerink sorry for this.
                                          @Bart-DM no need to!
                                          UltraStar
                                          UltraStar
                                            Lluís Casals
                                            Lluís Casals
