  4. CarPlay - Icon Position
6 Posts 2 Posters 50 Views
  • Frappawotsit
    Frappawotsit
    Frappawotsit
    wrote on last edited by Frappawotsit
    The Triangle icon showing your own position is not in the lower centre as it should be (as with other mapping software) instead it's on the right hand side lower, with itself and route ahead almost entirely hidden by the information banners on the screen. I don't know if this is particular to the UK with right hand drive cars, or if all instances are the same.
    When manually moving the screen, as soon as you select "done" the screen moves back to it's default position on the right side hidden by the information banners.
    Currently this is making the app un-useable with Car Play. It's worth noting that the icon is correctly in the lower centre when not connected to CarPlay and just using the Navigation app on the phone.
    • Frappawotsit Frappawotsit
      @Frappawotsit we still need to take UK oriented devices into account 🙂
      Frappawotsit 1 Reply Last reply
        Frappawotsit
        Frappawotsit
        Frappawotsit
        @Corjan-Meijerink Thank you, I did think this may be specific to right hand drive cars as the information banners are on the opposite side of the screen.
        Is this something that's being actively developed, or is it likely to be a low priority and therefore slow progress?
          @Frappawotsit I’m sorry, but you use the old MRA Navigation app - not the Beta 😉
          It will be fixed before release for sure! It’s important 🙂
            Frappawotsit
            Frappawotsit
            Frappawotsit
            @Corjan-Meijerink my apologies, thanks.
              @Frappawotsit no need to apologise! Your point is still valid 😉 The current Beta won't support this correctly either - but as said we will make sure this is fixed in one of the coming updates!
              Frappawotsit
              Frappawotsit
                Lluís Casals
                Lluís Casals
